Thread: fill water advance testing
    Mar 2011
    Webster, NY (Near Rochester)
    9
    So I have my test kit ready to go, new pool going in later this month. I'll be filling via the garden hose. If I test the water now (because I'm dying to play with the new toys) should I expect my readings to match the fill water a few weeks from now fairly well? I'd assume a municipal feed would be fairly consistent but never really thought much about it.
    Any thoughts?
    Steve C. in Webster, NY
    24x54 Aboveground, 1 HP 2-speed pump, 120 sq ft cartridge filter
    8 gallon Liquidator
    2 happy children swimming
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: fill water advance testing
    Testing now will let you prepare for the future. TA and CH are the primary levels of interest.
    Test results now will be close to what they will be in a few weeks, but may or may not be exactly the same. Depending on where you live there can sometimes be significant seasonal variations. A few weeks is likely to be well into the spring rainy season many places, so some changes are possible.
    The key tests to do on your fill water are TA and CH. Most people don't run out of those reagents, so I would go ahead and test those two now and then test them again when you are ready to do the fill.
    (A little more detail on what JohnT already said.)
    Mar 2011
    9
    Thanks folks, appreciate the advice!
    8 gallon Liquidator
