Results 1 to 15 of 15
Thread: CPVC leak from pump
    Yuma AZ
    71
    CPVC leak from pump
    Hello to everyone, I'm fairly knowledgeable working with PVC repairs but I will require very detailed instructions.
    Pipe is leaking just below the fitting coming from the top of the pump. (Pressure side Any suggestions on a better setup or perhaps using a quick disconnect union in this area would be greatly appreciated. I attempted to highlight in red the leaking fitting. The discolored PVC is from 3 seasons of intense SWArizona heat
    Thanks in advance for your help.
    [attachment=0:3cwkbutv]Filter Pump leak.jpg[/attachment:3cwkbutv]
    10,000 gallons IG Freeform, 8ft raised spa,pebble finish
    FNS 60 Sqft DE Filter,2HP Whisperflow for Pool/Spa filtering
    2HP Whisperflow for Spa jets
    1HP Whisperflow for Waterfall
    Master Temp 400,000 Btu Heater
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: CPVC leak from pump
    I'd probably put a union in the longest stretch of straight pipe to the right of the pump. Actually I'd probably replace that whole run and add a union above the pump. That way you can tighten the threaded fitting later if needed. I'm always paranoid about overtightening it.
    The adapter going into the pump doesn't look like a typical pool part since it's smaller than the ell. When you replace, use pipe joint compound designed for plastic pipe
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    I'd just replumb from the pump to the last elbow before the filter. Cut the pipe about halfway between the 90 and 45 elbows, unscrew it from the pump and toss it, and you'll be good to go. Make sure you clean the threads really well and use LOTS of pipe dope; those threaded joints are very prone to small leaks, as you've just learned
    Yuma AZ
    71
    Melt in the sun: Got it, should I use a union or not?
    John T: The gray pipe is a threaded adapter which was threaded on both ends. The pb cut the other end and used it as a slip into the 90deg.
    So I should use the sch80 with a union? I guess the question is to union or not to union?
    Oh is all this available at Lowes or HD? I have the pipe dope,blue glue, and a good hacksaw blade.
    Jun 2010
    Glendale, CA
    513
    I think most of us would Union when ever possible. If you ever need to change the pump in the future, life is much better.
    I've seen 1 1/2 and 2" unions at HD. Kinda hit or miss though.
    16K Gal Plaster | Compupool SWG | Intelliflow VF | TF-100
    22,553
    I'd use 2 unions on the discharge piping of the pump (see red squares). One on the top of the pump and one on the horizontal section. Raise that 90 up that right on top of the pump. That way you could remove the entire section if you ever had to work on the pump or the filter.
    Yuma AZ
    71
    Finally finished the new piping from pump to filter. I still have a very small leak from the top of pump, but the pump primes almost immediately. I have a shaft seal leak to tackle next weekend. Thanks to all for your help.
    [attachment=0:cvkhv6fq]resize new plumb.jpg[/attachment:cvkhv6fq]
    Mar 2011
    Scottsdale, AZ
    406
    Get some cheap almond spray paint and protect those pipes.
    The sun will kill them with out it.
    Plus it makes the whole set look a lot nicer.
    PVC that isn't painted starts to look fairly awful after a while, but it doesn't fail just because of sunlight.
    Yuma AZ
    71
    I plan to erect some type of sun shield for the equipment, will try the spray paint for a uniform look. Anyone know of a UV type of spray paint for PVC?
    Krylon Fusion is very good for PVC.
    Mar 2011
    441
    UV rays will degrade the plastic.
    20X40 30,000 gallon gunite pool
    Yes, UV will degrade the plastic, and it will look awful after a while, but it takes something over 100 years in a brightly sunlit location before it degrades enough to actually fail. No one will still have their original PVC after that long, so you don't need to worry about it failing.
    SW Indiana
    9,199
    When I moved my equipment, I was surprised at how brittle the PVC that had been exposed to the sun had become. Certainly not to the point of failure, but sawing the pipe that had been exposed for a few years produced scallops where the material chipped away at the cut, while the new pipe or the pipe that had been underground produced the normal "fuzz" on the cut.
    I was surprised at the difference. I don't believe it would make a difference in an undisturbed installation, but if your winterization process sees you flexing the pipe to get things disconnected, I could see a joint failing eventually due to it becoming brittle.
    This is only one experience with one brand of pipe, but I believe that when combined with the esthetics of painted pipe, that it is worthwhile to paint the exposed PVC.
    Mar 2011
    Scottsdale, AZ
    406
    I recently finished a pool that had been started over two years ago. All of the plumbing was left in open trenches.
    The pipe was so brittle when you moved it, it snapped, and you could take a rock and poke a hole in it easily. Obviously we replumbed the whole thing.
    PS. This is why it is required by local code to be painted. Sun here is brutal
    Here is a little tech sheet on this for a two year study. http://www.pwpipe.com/literature/tb/tb-d9.pdf
    Though pipe may not fail, why would you want to risk damage when paint is so cheap.
