Thread: Would like some advice on placement of solar panels
    linda1's Avatar
    Mar 2010
    Western Pa.
    298
    We purchased 2 Fafco 4x20 sunsaver solar bear solar panels and would like to figure out where to put them so we can purchase the necessary supplies to get the plumbing put back together. We put the heater, filter and pump in the garage for the winter. I attached a rough drawing as to where my husband would like to put the panels. The will be on some sort of rack. Would this be too far from the pump? Any suggestions, advice etc. would be appreciated.
    30 ft. round Conquest agp, 19,800 gal; Pentair Easy Clean 1 hp DE EC60 filter system
    Hayward H250N gas heater; TF100 Test Kit
    Dolphin E 10 ~ Zoomerang slide
    Majestic 8000 Above-Ground Pool Step
    Re: Would like some advice on placement of solar panels
    I'm not sure how closely everything is to scale, but that looks like it will be fine. As long as the panels are within 40 or 50 feet of the pump you should be just fine. Further away can be done as well, but you might need a larger pump.
    JesseJames's Avatar
    Sep 2009
    Florida
    64
    My layout is similar to yours and the solar panels are on the roof of the garage.
    13K Gal., Plaster, SWG, Intellichlor IC 20, Sta-Rite 1 HP Pump, Sta-Rite PLM 300 Filter, Pentair LED, Solar, Screened Enclosure, Great White, TF-100
    linda1's Avatar
    Mar 2010
    Western Pa.
    298
    Nothing is to scale. I did measure the distance from pump to pool, so the 20 feet is correct. Thanks.
    I would love to have them up on the garage roof, but the roof faces east and west.
