Results 1 to 9 of 9
Thread: Speed Stir
    SW Georgia
    300
    Speed Stir
    Has anyone had the light go out in their Speed Stir? Can the bulb be replaced?
    35K IG Vinyl 20 x 40 self built pool, Hayward Pro Series High-Rate Sand Filter 31" 98gal/min, Hayward TriStar 1.85hp, Hayward 400btu heater, BBB method w/Hypo, Jazz light w/matching fiber optic rope lighting around coping w/syncronized color wheels. Concrete Paver deck.
    Mar 2010
    Spring, TX
    1,082
    Re: Speed Stir
    Hopefully someone will be along to answer your questions. Dont you just love the speed stir. I have tried to use the light option a few times, but seems harder to use with the light on.
    I think it is made by taylor.
    So you may want to check out their site and email them
    http://www.taylortechnologies.com/home.asp
    Here is the part on their site to refer to
    http://www.taylortechnologies.com/produ ... artID=2300
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Speed Stir
    It's a bunch of LEDs, not a single bulb. I bet there's a loose wire somewhere, and if you can get the thing open it shouldn't be too difficult to figure out where the problem is.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Re: Speed Stir
    Check the batteries. Unlike old fashioned light bulbs that get dimmer and dimmer, LEDS work down to a certain voltage then just stop.
    Woodberg's Avatar
    Apr 2009
    Houston, TX (Candlelight Estates)
    136
    Re: Speed Stir
    My speed stir doesn't stir, it just vibrates in the bottom and agitates the water. Is this the way its supposed to work or should it actually be spinning?
    20,000 gallon gunite pool, attached spa, Pebblesheen finish, Paramount PCC-2000 infloor cleaning system, Paramount ClearO3 ozone system, Intelliflo VS main pump, Whisperflo 1HP cleaner pump, StaRite cartridge filter, StaRite heater
    22,544
    Re: Speed Stir
    It should actually be spinning. First thing to do is change the battery with a known good one. Then try a different magnet.
    Mar 2010
    Spring, TX
    1,082
    Re: Speed Stir
    Quote Originally Posted by Woodberg
    As already stated, when you put the magnet in the magnet itself should spin. The tube will not spin only the magnet should. If you are not getting any spinning of the magnet, change out the batteries as stated above. Mine was doing the same as yours, changed the batteries and all was back to normal.
    Woodberg's Avatar
    Apr 2009
    136
    Re: Speed Stir
    I changed the batteries and now its working great again. I didn't realize that weak batterys would do that. Thanks.
    Mar 2010
    Spring, TX
    1,082
    Re: Speed Stir
    yeah I was stumpped as well. New batteries work great.
