Results 1 to 14 of 14
Thread: Aeration
    rwrogers11's Avatar
    Apr 2011
    Katy, Tx
    66
    Aeration
    I was thinking of putting a T into my return line, coming up with 3/4" pvc, and putting a water spicket on it. Then using a short hose connected to a cheap plastic sprinkler, sitting on top of my deck which is level with the top of my pool, to use as an aerator. When the pump is running, I could just open the spicket a bit and turn on the sprinkler, and of course have it pointing back into the pool. I figure this would work for aeration, as well as to help cool the water temp during the summer.
    Does this sound like it would work?
    Richard
    Pool - 18' Doughboy Above Ground Vinyl, 7600 Gallons, 1HP Hayward Power-Flo Matrix pump, Hayward Star Clear Cartridge Filter C500 50 GPM flow rate, Hasa Chlorine Injector, Pool Rover Vacuum, Taylor K-2005 Testkit - Hot Tub - Artesian Pelican Bay, 550 Gallons, Ozone, Nature 2 Mineral Sanatizer, Bromine floater.
    Apr 2010
    Buckeye, AZ 85326
    619
    Re: Aeration
    When they installed my equipment they installed a spicket just like you are explaining. I have used it for aeration and it worked just fine. It also comes in handy for other things as well.
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Aeration
    Yes, but you might need either a 3-way valve or a valve in both the return line and in the line to the aeration device. If your return fitting restriction is low, you might need to partially restrict the return to get a good flow.
    I wouldn't mess with garden hose size fittings or a sprinkler. You really want more water than that. I'd just use about 1" PVC with some holes drilled in it as your sprinkler. More flow would mean more aeration. You could experiment for some cool effects visually as well.
    rwrogers11's Avatar
    Apr 2011
    Katy, Tx
    66
    Re: Aeration
    Cool. Well I have pleanty of pressure. You can ride the rapids around my pool on a float if you wanted. I almost think I have too much. But I have enough to pressure a spicket as well. I think I'll try a sprinkler first, if it doesnt do enough, then I'll build one out of pvc and see what that does.
    Richard
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    Re: Aeration
    They already make plenty of different kinds of "sprinklers" you can just screw into the return and replace the eyball. Mine will shoot 15 feet in the air above the pool! all the aeration and colling effect you need. They run around 25 bucks or so.
    You need more than that? It's a cold hard rain standing under mine.
    rwrogers11's Avatar
    Apr 2011
    Katy, Tx
    66
    Re: Aeration
    No that would be fine, I'm just lazy and looking for something that I can put inline and turn on / off when I want to, rather than hooking it up to the return and then having to take it off each time. I only have one return, and if I leave it on, I'm not sure how well the circulation would work. Whereas if I leave the return as is, and put a sprinkler inline, then I can turn the sprinkler on and off when I want, without affecting the return and / or circulation.
    Richard
    crookm11's Avatar
    Jun 2010
    Copperas Cove, Texas
    422
    Re: Aeration
    Quote Originally Posted by rwrogers11
    Hello,
    I know you have a hard side AGP but you may want to look at my thread about this same thing. I added an extra return in the process. Just an idea.
    Fountain and Extra Return.
    Mark Crook
    13,500 Gallon 24' x 52" Intex Ultra Frame
    Intex Sand Filter and Pump, Intex SWG (All hard PVC plumbed)
    TFTestKit-100---Pool School---The Pool Calculator
    Location: Copperas Cove, Texas --- My Pool Build---Useful Links for Intex Pool Owners
    rwrogers11's Avatar
    Apr 2011
    Katy, Tx
    66
    Re: Aeration
    Well here's what I wound up building, its not the best but for $ 15.00, it will do.
    Richard
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: Aeration
    Looks good.
    I hope I don't derail this thread too badly, but....
    your signature says "...3" chlorine pucks in floater, Pool Rover Vacuum, Taylor K-2005 Testkit." I have no problem with the vacuum. The pucks are another story. You're just adding and adding CYA to the pool. Have you tested the level lately? If it's above 60, your minimum free chlorine is going to be higher than that color-matching test block can read.
    It is possible to manage a pool with high CYA; I did it all last summer by necessity. But I had to maintain FC up in the neighborhood of 20, which required the FAS-DPD test. Not all is lost for you, however, that test is available separately, which will essentially upgrade your K-2005 to a K-2006.
    Welcome to TFP.
    Jan 2010
    Central Valley, CA
    233
    Re: Aeration
    great, now you've just given me yet another project!
    PVC art, a great hobby.
    Garden Leisure Voyager 12x24 AGP, 7500 Gallons, Hayward Power Flo Matrix 1 HP pump, dual speed, Hayward XStream Cartridge Filter, 120 GPM,
    crookm11's Avatar
    Jun 2010
    422
    Re: Aeration
    Awsome job on the fountain!!!
    Mark Crook
    rwrogers11's Avatar
    Apr 2011
    Katy, Tx
    66
    Re: Aeration
    I'm currently using pucks, but I've ordered the liquid chlorine injector. My CYA right now is at 28, so I'm fine for now.
    Well the next one I build, will have either smaller or fewer holes, to get a little more pressure from it.
    Richard
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Aeration
    Just a note. Some people point the aerator jets down slightly into the water as shown in this post which has the advantage of involving a larger surface area of the water in getting churned up. Also, pointing other returns up with the pump on high also works to some extent. You are correct that making the holes smaller to get a faster and narrower jet action would be beneficial, but probably better if directed somewhat towards the pool surface unless your goal was more of cooling the water via evaporation.
    jwhop3's Avatar
    Jun 2014
    Rocky Mount/Virginia
    78
    Re: Aeration
    Maybe try a D-shape loop with two elbows and a short straight. Then drill all three sections to create a fanning spray?
    Quote Originally Posted by chem geek View Post
    14,000 gallon Fox Lagoon, ingound vinyl
    PacFab Sand filter
    installed April, 2002
    Frog inline chlorinator
    Town water
