Thread: Location of Return Hose
    location of return hose in relation of the skimmer.
    any thoughts from anyone as to have the return hose positioned say 12" from the bottom?
    I'm having a 18'X34'X52" oval above ground pool installed and thought by having it at this location it would improve the circulation.
    Thanks!
    25,000 gal. inground
    vinyl liner
    Hayward sand filter
    Circupool SWG
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Location of Return Hose
    I'm pretty sure the return opening hole is pre-drilled on the pool wall, but perhaps as a 2nd return?
    Moving the return lower than normal can improve things, but only just a tiny bit. It is more important to get a return fitting that can be aimed, which gives you much more flexibility and makes the depth irrelevant.
