Results 1 to 8 of 8
Thread: Moving to a new house with an older pool, skimmer options?
    Mar 2011
    Tempe/AZ
    117
    I'm located here in sunny Arizona to start. Also this is my 1st post so I look forward to learning more about proper pool care. My question is the house were moving into next week has an older pool. It has a plaster interior and it's 10ft deep with a diving board, it's also inground. The pool is chlorinated but I plan on using the BBB method to take care of it. Luckily the entire pool was recently drained so the CYA levels should be fairly low. I have the TF100 kit on order so once I move in I can start with proper chemisty. By then it will be May and the pool temps should be 85ish give or take a few degrees.
    My question is about this older pool. The pool cleaning system has your standard pool vac that runs along the floor of the pool. The suction area where you connect the hose is located in the skimmer. There is no basket in the skimmer, so I was wondering if there was some special type of basket that is made which allows the skimmer to do it's job and collect all the leaves and floating debris but also allows the hose to pass through it so the vac can do its job all at the same time? I have a few pictures I took of the house when we were there with the inspector. I can't get any better pictures until we close on the house and have keys in hand. I was hoping to find the piece I needed and have it ready for when we move into the new place. Here are a few pictures of the pool to give you a visual.
    Full shot of the pool.
    In this picture you can see the hose going into the only skimmer in the pool. Again there is no basket to the skimmer, what would you recommend I do?
    28,000 gallon IG, Plaster Interior
    Hayward Sand Filter
    Pentair Inteliflow VS Pump 3HP
    20+ Years old and use TF Test Kit
    *Pool remodel coming 10/01/14 details to be in new thread
    Feb 2008
    Denton, TX
    5,061
    Re: Moving to a new house with an older pool, skimmer option
    Maybe someone else knows of one, but I don't really know of a device that would allow you to skim and run a suction side cleaner simultaneously. You typically are able to do one or the other but not both.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    As far as I know there is no part like you describe available. In face if that is the standard skimmer with a single hole in the base you cannot skim and vacuum at the same time with only only 1 skimmer. You do not have to have the cleaner running all the time. You can disconnect the vacuum and put a basket in the skimmer to catch any floating debris.
    Love TFP? Become a
    TFP Supporter!
    Mar 2011
    Tempe/AZ
    117
    Ah so this must be common for older pools I take it? The pool at our current house we had built brand new in 2007 has a separate skimmer and a separate suction line for the pool vac.
    Hayward Sand Filter
    Feb 2008
    Denton, TX
    5,061
    Quote Originally Posted by Matrix311
    That's correct. That is how they are doing things these days.
    Jul 2009
    Houston, Texas
    9,377
    Some people just want a basic, no frills pool, and everything you add increases the cost, so you will still see new pools built this way. If you like the idea of a cleaner going constantly, you could invest in a robotic pool cleaner. After you have been in the house a few weeks you will have a better idea of how often you will need to clean the pool.
    Love TFP? Become a
    TFP Supporter!
    Pierre!'s Avatar
    Mar 2011
    15
    Hello Matrix311, my fellow 'Zonie'...
    Thanks for asking a question I have been wondering about! It would be nice to keep all the debris from entering the sand filter and eating up all my chlorine...
    I will be watching to see what 'the answer' might be.
    You are going to appreciate the FT100 for sure. Very Useful tool.
    Fine looking Hacienda you are working on! Hope the acquisition goes through easily, and on time. Thanks for doing YOUR part in the Economic Stimulus... Seems like no one in 'power' is willing to do much...
    Okay... Moving Right Along...
    We'll see you around,
    Patrick
    Pool Capacity - 17,000+/-,Sand Filter on IG plaster style older build, pump size TBD
    Free eBook! ---> Internet Safety Tips - "The Essentials" ---> The Seeber Consulting Blog
    Mar 2011
    Tempe/AZ
    117
    Re: Moving to a new house with an older pool, skimmer options?
    Hey all I just wanted to post an update. I ended up buying the poolskim. It's done an amazing job keeping my pool clean. Here is a link to it just in case someone else shares their pool cleaner with their skimmer.
    http://www.poolskimusa.com/
    Hayward Sand Filter
