Results 1 to 10 of 10
Thread: Is my new pool pump an upgrade?
    Denton, TX
    14
    I am planning to replace my 2.5 HP Pentair Challenger pump with a 3/4 HP Pentair Whisperflo pump. Is 3/4 HP enough?
    16K gal, IG plaster, DE filter, 2.5 HP Pentair Challenger
    22,549
    Re: Is my new pool pump an upgrade?
    Tell us about your pool equipment. Any waterfalls or other water features?
    Denton, TX
    14
    The hot tub has a spillover into the pool. I've got a Polaris pool cleaner. The pool is 9 ft deep at it's deepest, if that matters.
    22,549
    Does your hot tub have jets? that may be the reason the pump was sized the way it was. Tell us more?
    Denton, TX
    14
    Yep. Hot tub has jets. I'm new at this, so I'm not sure what other info is relevant.
    22,549
    Anything that you can think of is relevent. How many jets, what size, any other features?
    Denton, TX
    14
    5 jets in the hot tub. It's about 375 gallons and has a blower. The drain on the hot tub is typically closed and the jets create the spillover into the main pool. There aren't really any other features to mention.
    A 3/4 HP pump is extremely unlikely to be enough to get the jets in the hot tub to work correctly. 3/4 HP is plenty for the pool alone, but you need something quite a bit larger to get the jets to function correctly.
    To add to what Jason is saying, I"d highly recommend getting a variable speed pump with enough rear-end (2HP, maybe?) to do the job on high but that can be run on low for day to day filtering.
    Clearwater, Florida
    12,000 gallon kidney shaped gunite pool
    Pentair Whisperflo 3/4HP Pump
    Pentair CCP420 420sq/ft Cartridge Filter
    Pentair Intellibrite 5G 120V Pool Light
    Denton, TX
    14
    Thanks guys. I may just fix my current pump then.
