Pool Pump Motor Replacement
Apr 3, 2011
1
Greetings, I currently have a Hayward Super II Pump that has gone out and needs replacement. I am unable to locate the exact replacement part for model number SP1607Z1MBK, can someone please assist me in locating the correct motor for my pump? Here are my pump's specifications:
C48K2N143B3 S/N
8J04 SER
1 HP
.75 KW
115/230 Volts
15.0/7.5 AMPS
3450 RPM
60 HZ
1.1 SF
Thank-you!
Welcome to TFP!!
(Going from memory :oops: a UST1101 should work, but I'd double check that :wink: )
If you need any help removing the old motor or replacing the new one [AND replacing the shaft seal assembly- you gotta replace that when changing motors], let me know - I've done 100s of these and could probably do it blindfolded :-D
