Thread: Pool Pump Motor Replacement
    Greetings, I currently have a Hayward Super II Pump that has gone out and needs replacement. I am unable to locate the exact replacement part for model number SP1607Z1MBK, can someone please assist me in locating the correct motor for my pump? Here are my pump's specifications:
    C48K2N143B3 S/N
    8J04 SER
    1 HP
    .75 KW
    115/230 Volts
    15.0/7.5 AMPS
    3450 RPM
    60 HZ
    1.1 SF
    Thank-you!
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    Re: Pool Pump Motor Replacement
    I found a motor at this website that says it is a direct replacement for your model. I have not ordered from this company before, but maybe someone else can give some feedback on their customer service.
    Love TFP? Become a
    TFP Supporter!
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP!!
    (Going from memory a UST1101 should work, but I'd double check that )
    If you need any help removing the old motor or replacing the new one [AND replacing the shaft seal assembly- you gotta replace that when changing motors], let me know - I've done 100s of these and could probably do it blindfolded
    Luv& Luk
    -Ted
    Aug 2007
    near the swamp
    806
    A.O. Smith ST1102
    Mar 2007
    4,160
    Quote Originally Posted by DBfan187
    A.O. Smith ST1102
    Thanks for the correction! (I was only off by 1 )
    Luv& Luk
    -Ted
