Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: Treating my greenish pool: encouragement please!
    LauleaHere&There's Avatar
    Aug 2010
    Rural Moloka'i, Hawai'i
    155
    We had the solar blanket on for a couple of weeks because of cooler temps and high trade winds. Uncovered it to find jade-colored water. (first time ever) So I followed instructions, tested, added Clorox, kept testing, adding, filtering, brushing, backwashing. Backwash water seems to be the same opacity as the pool water. Not sure how much I'm gaining with the backwash. (pressure gauge is busted, and won't be replaced until I get to the mainland next month)
    CYA=60
    FC between 25 and 16, depending on where I am in the testing cycle.
    After two days, I'm still losing FC overnight. Water is milky, despite constant filtering.
    Am I on the right track?
    12' round above ground pool. 3,500 gal. Vinyl liner. Waterway Supreme Hi-Flo 48 frame pump. 1.5 hp. SWG. Sand filter with Zeobrite.
    Thanks, members of Trouble Free Pool, for being so friendly and informative!
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Treating my greenish pool: encouragement please!
    With CYA at 60 your shock target is around 24 and try your best not to let it drop down below that. the filter should be running 24/7 and unless your return flow falls off too much, you can hold off on backwashing so much. Sand filters then to be a bit more efficient at filtering out algae the dirtier they get.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    According to your CYA level----24 is your shock value for FC. You're going to have to KEEP it at that level until it's all dead. Drops down to 16 is where your problem is. I'd assume that the cya of 60 is probably a bit undervalued and go a little higher on the shock level for FC. Try and maintain it at 28- 30 for some "margin of error". Keep filter running constantly and backwash frequently as you have been and you'll get there.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Backwashing is a good idea when the filter is too dirty. Asuming the filter has good flow, too frequent backwashing with a sand filter will lengthen the time it takes to filter out algae. Hate to say this but sand filters do the worst job of filtering dead algae, but the dirtir they get, the finer particles it will capture. This is one of the reasons adding a little DE to "dirty" the filter can help speed up clearing.
    30,431
    Absolutely. Holding your FC a little higher may or may not help speed things up but it darn sure wont hurt anything. Now is the time for patience. It usually takes me about 4-6 days to clear my pool. (not that mine ever gets green.....I'm just sayin' it PROBABLY would take me 4-6 days )
    Aug 2010
    155
    Yeah, I have good flow. Maybe too good, since my pump is a little over-powered for the size of my pool. I've boosted the FC to 28 and will test more frequently to make sure it stays in the shock zone.
    Thanks, guys.
    Apr 2010
    East Texas
    9,643
    Good try-----------------but YOU'RE BUSTED Duraleigh!
    Aug 2010
    155
    So, most of the "Clearing Your Swamp" tutorials mention that there are different rules for a new outbreak, but no one says what they are.
    Can somebody clarify? Thanks.
    Apr 2010
    East Texas
    9,643
    Shocking is still shocking..
    When you are dealing with a total green swamp you want to get everything in place and make sure you have some time available to deal with it correctly. When you are fighting a brand new algae outbreak you can save a lot if time if you catch it quickly and get as much chlorine in right away as you can, even if that means not being totally prepared. Other than that, the basic procedure is the same.
    Aug 2010
    155
    OK, thanks, Jason.
    Oct 2010
    Georgia
    317
    My son cleared a green 30K+ gal inground pool for some friends. He maintained shock level, brushed and backwashed daily. The water turned dark blue in 2 days, but it took over a week before the sand filter could clear the water enough to see the main drain. It took another week before the water looked normal. He added a little DE powder to the sand filter and within a few days the water regained it's former sparkle.
    Spring pool cleanups can be a good source of income for broke college students.
    poolschoolgrad
    20x40 free-form IG vinyl, 1hp Hayward superpump, Hayward pro grid DE filter, Raypak heatpump, Goldline Aquarite SWCG, Polaris 280 with booster, and tested using a Taylor K2006.
    Aug 2010
    155
    I'm seeing daily improvement in clarity, maintaining shock level pretty well, though still losing too much FC over night. So on we go.
    It is reassuring to hear that it takes more than a few days to clear the haze.
    Jul 2009
    London and France
    574
    Quote Originally Posted by woodyp
    Aug 2010
    155
    Another night gone by and my overnight FC is still dropping too much. (last night from 27 to 22)
    I don't get it. The water seems to be clearing, I brush twice a day. How much longer should I keep this up?
    22,553
    Not meaning to be smart, but as long as it takes! Sometimes it takes a little while after it's clear, sometimes it's finished before it's clear and sometimes it takes a little longer after it's clear to stop losing FC overnight. Keep it at shock level as often as you can.
    Oct 2010
    Georgia
    317
    It is going to take a little bit longer than average because of the warmer water temps, but
    hang in there you are about half way there at this point.
    The water should have turned from a dark green to a dark blue.
    Next it will turn blue/grey.
    The blue/grey should be getting lighter each day.
    You should be seeing white/grey particles suspended in the water. This is dead algae. Once all the algae is dead it still takes some time for the filter to remove all the dead algae from the water.
    Free Chlorine loss of 5 ppm overnight means you still have some stubborn algae remaining in the water. Keep your water at shock level....You will win the battle !
    You may have a day or two about half way in when it appears nothing has changed and you are certain something is wrong.
    This is probably where you are at this point.
    Give it a few more days and you will be surprised as you wake to a much clearer pool.
    poolschoolgrad
    Aug 2010
    155
    BamaRambler and poolschoolgrad, Thank you! That is just what I needed to hear. The Spouse is doubting my mad pool skillz and starting to complain about all the gallons (tuh, only 8 so far) of Clorox I'm bringing home.
    Things will be a little more complicated until my refill of R-0871 arrives. But duraleigh has already shipped, so it should be about 3 days. I have 2 or maybe 3 tests worth left.
    Oct 2010
    Georgia
    317
    Your mad pool skillz are fine, the family just needs a little POP. Pool Owner Patience.
    With limited R-0871 allowing fewer tests, a rough guess of
    3 quarts per day at this stage should be enough to restore the chlorine from 15 up to 25+ in a 3500 gal pool.
    To make the most out of the little R0871 that remains, dilute the pool water sample with 1/2 tap water and double your results.
    Your results will not be as accurate, but will be close enough at this point. 10 ml sample size is accurate enough for now as well.
    Hang in there
    poolschoolgrad
  20. Back To Top    #20
    Jan 2010
    Central Valley, CA
    233
    Quote Originally Posted by LauleaHere&There
    price bleach against pool store supplies for "shock"!
    Garden Leisure Voyager 12x24 AGP, 7500 Gallons, Hayward Power Flo Matrix 1 HP pump, dual speed, Hayward XStream Cartridge Filter, 120 GPM,
