Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Need Serious Help Fast.
    Jan 2011
    south louisiana
    43
    Just got my pool redone, this means chipped all the way to the gunnite and replastered. And now as im filling it its about half way finished I see a shot load of rust stains popping up. So I stopped filling it at halfway like a friend told me and called the people who done it who have yet to return my call. Why is it rusting like this? Should I cancel the second half of the payment? Anyone have any ideas or thoughts on this? Its an inground pool. I do have pictures of before and after which I can try to post. All I did was run water from the hose to the pool which they are the ones who actually did that cuz they said I could start filling it as soon as they were done.
    dont know how many gallons i got but if i remember correctly the pool is about 20'wide and 32' long and goes from 4 to 8 foot. I think i remember someone telling me about 35k in gallons but i could be off.
    filter type-Sand
    its an in-ground plaster
    dont know the size of the pump or size of the filter.
    http://m1099.photobucket.com/albums/vodkacop/
    Jan 2011
    south louisiana
    43
    Re: NEED SERIOUS HELP FAST.
    I think these will come up
    filter type-Sand
    Jan 2011
    south louisiana
    43
    They didnt come up I can email them if anyone wants to see before and after
    filter type-Sand
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    If it's iron in your water, try holding a vit c tab against it to see if the stain lifts. Regardless, you should get the PB out ASAP and if possible hold back payment until the job is done to your satisfaction. If there was a contract, did it include ensuring the new plaster start-up?
    Don't stop filling. If you stop filling there will be a permanent line at the current water level and the plaster above there might not get enough moisture to cure properly.
    Do you have a plain plaster finish, or is there something extra, pebbles, quartz, etc, in the plaster?
    Jan 2011
    south louisiana
    43
    Plain plaster. I don't know what you mean by getting the PB out asap sorry. Are y'all sure I should keep filling it? I was told by a friend who is a pool cleaner to stop filling it. Also filling it will take time and more on the water bill which is already ooutrageous from draining it and filling it as high as it is. Also with them using my water to mix their ingredrients like the concrete and plaster.
    filter type-Sand
    phalcon51's Avatar
    Oct 2010
    So. California
    203
    I would follow Jason's advise - DON'T STOP FILLING THE POOL! THE PLASTER WON'T CURE PROPERLY!! The pool builder probably won't cover any problems related to not filling the pool! Your pool cleaner friend is not a replastering specialist and I don't think he's going to cover any damage you might cause by following his advice. Continue filling the pool and do whatever you have to to get the pool builder (pb) out there asap to find out what the problem is. Hold back on the final payment till the problem is taken care of to your satisfaction.
    Just my $.02
    26,200 gal. 35' x 16' Plaster IGP (50 yrs. old), Hayward 48 sq. ft. DE filter, Hayward EcoStar VS pump, Intellichlor IC-40 SWCG, The Pool Cleaner 4X suction, Pool Skim and Pool Devil skimmers. Re-plastered Sept. 2010.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Please keep filling it, whatever has been done by using your water to mix the plaster and fill the pool can be dealt with more readily than the plaster curing issues mentioned by Jason.
    Luv& Luk
    -Ted
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    Not to be piling on, but new plaster needs to stay wet. You don't want the pb (pool builder or in your case plasterer) to say you have voided your warranty by not filling the pool as per instructions. The pb should be able to treat the pool and get rid of the stains.
    Try using photobucket.com to host your pictures. It is free and fairly easy to use.
    Love TFP? Become a
    TFP Supporter!
    Jan 2011
    south louisiana
    43
    Ok thanks all ill keep filling it.
    filter type-Sand
    Jan 2011
    south louisiana
    43
    Ok the hose running again but in the grand scheme of things I only missed maybe two hours of my slow hose pipe filling the pool so as slow as it is im thinking I didn't miss a whole lot. So should I get into the pool and put a vitamin C tablet by one of these rust looking spots?
    filter type-Sand
    Jan 2010
    Central Valley, CA
    233
    whew, lots of drama reading this thread! glad you didn't have the hose stopped long. Good luck with your stains.
    Garden Leisure Voyager 12x24 AGP, 7500 Gallons, Hayward Power Flo Matrix 1 HP pump, dual speed, Hayward XStream Cartridge Filter, 120 GPM,
    22,553
    Post your photos on photobucket or some other hosting site and link them here.
    Jan 2011
    south louisiana
    43
    Could it be the hose that was put in the by the PB? Im thinking it can't be cuz the rust spots aren't around the hose except for one in the deep end. Also putting the pictures on pgotbucket at this time.
    filter type-Sand
    A 20' x 32' pool is unlikely to be more than 28,000 gallons and is probably much less than that.
    Jan 2011
    south louisiana
    43
    filter type-Sand
    Re: Need Serious Help Fast.
    Alright, having seen the pictures I will update my size guess to between 28,000 and 30,000. The shallow end is smaller than most and the corners are squarer than most.
    Jan 2011
    south louisiana
    43
    Cool thanks
    filter type-Sand
    Aug 2010
    New Caney, TX 77357
    184
    Quote Originally Posted by vodka
    My new pool had to be drained and acid washed due to splotchy appearance of plaster (pebblefina). The PB is paying for cost of water to refill plus new startup chemicals. If yours has to be drained for rework due to the staining I would expect your PB should do the same.
    20K gal, inground with attached spa, pebblefina plaster (bella blue), flagstone coping, moss rock waterfall, Sundek - Indian wheat, (2) Jandy PHPM2.0 (filter pump and waterfall), Jandy DEV60 DE filter, Polaris 280 pool cleaner, Polaris Halcyon PB4-60Q booster pump, Polaris 1.5 HP Air Blower, (2) Jandy WaterColors LED lights, Jandy LXI400P Heater, Jandy AquaPure PLC1400 SWG, Jandy AquaLink RS PureLink Controller and PDA.
  20. Back To Top    #20
    Jan 2011
    south louisiana
    43
    well the pool is full and the PB will be there in the morning. ill let yall know more later..now too search on for a pump for my in ground because apparently i have an Above ground pool in my in ground pool..so all suggestions of the kind and names of pumps are appreciated..
    filter type-Sand
