Results 1 to 16 of 16
Thread: The pool store guy says...
    Mar 2011
    Webster, NY (Near Rochester)
    9
    ...that using liquid chlorine to maintain the pool adds lots of calcium to the pool. "only some die-hard old-timers still use the liquid"
    I thanked him for his advice (that only their Chemicals are the "smart way" to go) and now I'm turning to a community with some pool sages to get a real answer. Any thoughts?
    Steve C. in Webster, NY
    24x54 Aboveground, 1 HP 2-speed pump, 120 sq ft cartridge filter
    8 gallon Liquidator
    2 happy children swimming
    Re: The pool store guy says...
    Liquid chlorine does not contain calcium. It contains sodium hypochlorite. Calcium hypochlorite is the only type chlorine that contains calcium.
    Support the site
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Here is a nice little write up on chlorinating options and their pros/cons
    pool-school/types_chlorine_pool
    Hmm, and how does the pool store guy feel about weekly shocking with powdered cal-hypo products?
    Feb 2008
    Denton, TX
    5,061
    Quote Originally Posted by anonapersona
    Something tells me that he would be fine with that as long as you buy your Cal-hypo from him.
    Mar 2011
    9
    Thanks all, I had read the pool school articles before my chat with the pool store guy so it took some self-control to get through the BS he was spouting.
    8 gallon Liquidator
    Sep 2010
    SC Lowcountry
    54
    Ran the first set of numbers with my new Taylor kit. The kit that the pool company gave me when I installed the pool didn't test CYA or CH. So after getting my results and plugging them into the Pool Calculator, there was a need to increase my CH (70) and CYA (45). I decided to let a local pool supply company analyze the water and compare the two. Out popped a fancy printout with a with all their recommendations ($100). She asked me when I last cleaned my filter and I told her last Sunday (3/27). For some reason she plugged the date (2/17) into the computer, which indicated that I needed "filter shampoo" (not included in the $100). I bought what I came in for and left. I sure am glad I found this site.
    Viking Laguna 14K IG , Smart Pure SWCG, SwimClear C5520 Cartridge Filter, TriStar 1.5HP, SmartControl PLP4 controller.
    Quote Originally Posted by noaliasneeded
    I gotta ask... what did they want you to add to the pool?
    22,553
    They have programmed all sorts of recommendations into their custom software. It's designed for one thing and one thing only. To generate revenue. It's not designed to help the pool owner at all.
    Like Anona, I'd like to know what all they said you needed.
    Sep 2010
    SC Lowcountry
    54
    1lb Alkalinity Increaser, 1.75lbs Stabilizer, 15lbs Calcium, 18oz Algae Inhibitor, 3lbs Maintenance Oxidizer.
    Preliminary numbers:
    FC 4
    PH 7.4
    TA 80
    CYA 70
    CH 250
    Salt 3000
    SWCG runs from 11am until 5pm @ 15%
    Correct me if I'm wrong. Wouldn't running my waterfall bring my PH back up to it's normal level of 7.6, or should I do that chemically?
    Yes, the waterfall and the SWG will both tend to drive up the PH over time. If this is troublesome you can lower the TA to 60 and let the PH go up to around 7.7 or 7.8. If it isn't a problem then there is no need to do anything.
    22,553
    With those numbers I wouldn't recommend anything. If your pH is stable I wouldn't do anything to bring it up. If the SWCG isn't raising it you're in really good shape.
    Sep 2010
    SC Lowcountry
    54
    Thanks guys. My efforts so far. Just need the water to warm up a little. Shouldn't take too long since the pool is in this much sun from 10am until around 4pm.
    30,431
    That's excellent water chemistry, noalias, and a great looking pool to go with it!! Nice work!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,052
    [center:14kmsn28]The pool store guy says you need
    What do I win for guessing correctly?[/center:14kmsn28]
    Richard wins Salesman of the Year for excellent product placement.
    Clearwater, Florida
    12,000 gallon kidney shaped gunite pool
    Pentair Whisperflo 3/4HP Pump
    Pentair CCP420 420sq/ft Cartridge Filter
    Pentair Intellibrite 5G 120V Pool Light
