Results 1 to 8 of 8
Thread: Help on calculating gallons that our pool has
    Apr 2011
    Palm Harbor, Florida
    90
    Noticed that profile signatures around here show total gallons in their pool. How can I calculate that for our pool?
    Our pool is mostly rectangular, but has a spa above pool level in a corner (waterfalling into pool from spa). In the opposite corner, is a step into the deep end of our pool, and this corner is "cut off" from the rectangle.
    I would probably just begin with this formula:
    Length x width x ( ( depth of deep end + depth of shallow end) / 2)
    To give me volume of our pool in cubic feet. Just need this converted to gallons. Would this suffice, or should my calculation be more precise for that when I share this information to local pool supply stores, this forum, etc?
    Thanks in advance!
    Florida-style enclosure (lanai) housing 18,000-gallon outdoor in-ground salt pool/spa, PeebleTec finish. Spa water waterfalls into pool. Hayward model 17502 cartridge filter system, Hayward SP3400VSP EcoStar Variable-Speed Pool Pump. One skimmer, Baracuda Zodiac MX-8 cleaner. Palm Harbor, Florida
    Apr 2011
    90
    Re: Help on calculating gallons that our pool has
    adding photos for clarity to what I am referring to
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    Have you seen the gallons calculator in the pool calculator in pool school?
    And you gotta allow for how much that gator drinks in a day too!
    Apr 2011
    90
    Yes - the link was down previously - now it's back up.
    Our pool is 13.5 x 30, and depth is an estimate (3 feet shallow end, 8 feet deep end, to make average depth about 5.5), it came out 16,700 gallons. However, our local store has a history on our pool from previous house owners and it is shown as 20,000, so I'm not sure if that is an estimation as well. There is a 2,300 gallon difference here - is 2,300 gallon difference significant when discussing what chemicals to buy for our pool maintenance needs?
    I guess that gator drinks 2,300 gallons, lol.
    Apr 2010
    East Texas
    9,659
    There's about a 1500 gallon difference from what the pool calc says mine is vs. what the manufacturer says. Split the difference and treat for that-should give you a real good idea on the FC test. Got a TF-100?
    Those "local store" numbers are probably the worst ones.
    Aug 2010
    Dallas, TX
    4,052
    I ran the numbers with the calc to get close, then treated according to the pool calculator. I adjusted the gallons for the pool until it matched what I was feeding the pool in chlorine. Probably more accurate than using the measurements!
    Apr 2011
    90
    Quote Originally Posted by RobbieH
    Sounds like something I want to do, but I'm not really following - can you expand a bit about this methodology? Thanks in advance
    Jan 2009
    Cupertino, CA
    1,966
    Quote Originally Posted by cflannagan
    The idea here is that adding a known amount of a chemical will have a predictable effect on your test measurements. For example, if you add 1 gallon of 5.5% bleach to a 10,000 gallon pool, your FC will increase by 5.5ppm (until it gets eaten by sunlight or algae). Assuming you have a clean pool and you do this in the evening, if you have to add 1.5 gallons to get a 5.5ppm increase, then you must have 1.5 x 10,000 = 15,000 gallons in the pool.
    --paulr
    BBB "Intermediate Swimmer"
