Page 1 of 2 12 LastLast
Results 1 to 20 of 35
Thread: Where to buy borax
    Jun 2010
    Pensacola FL
    40
    Where to buy borax
    Went to buy borax at the local Wally world and was told they no longer stock it. It was too expensive at the local grocery store. So if anyone is interested I found the 76oz boxes at buy.com for $4.29 no tax with free shipping. The fed ex guy is going to be ******.
    14.5 K inground vinyl
    1hp pump
    sand filter
    Taylor K-2006
    Aquarite SWG
    P'cola FL
    gpgyo's Avatar
    Dec 2010
    Houston, Texas
    28
    Re: Where to buy borax
    I bought 8 boxes at the Target in my neighborhood yesterday. They were $3.00 a box. Went in the pool this morning and it's looking better already!
    Good luck.
    Jun 2010
    Pensacola FL
    40
    That's great. They were over 4 at my target and they didn't have enough
    1hp pump
    sand filter
    Taylor K-2006
    Aquarite SWG
    P'cola FL
    I've seen borax many different places, but few seem to keep it in stock consistently. In addition to WalMart, Target, K-Mart, and some of the big box hardware stores, try a few of the largest grocery stores in you area.
    I'll back up Target. Got some for $3.29 the other day. You may also want to check the dollar stores. I think Family Dollar carries it.
    Clearwater, Florida
    12,000 gallon kidney shaped gunite pool
    Pentair Whisperflo 3/4HP Pump
    Pentair CCP420 420sq/ft Cartridge Filter
    Pentair Intellibrite 5G 120V Pool Light
    Publix grocery stores seem to be good about carrying it.
    33,000 gallon in-ground L-shaped, vinyl liner, Heyward sand filter, Polaris 280, TF-100
    Northeast Georgia
    Mar 2011
    Monaco
    23
    I saw this Boric Acid on Ebay the other day. Can anyone comment on its suitability? Other wise on mainland Europe I have no idea where to by it....
    BORIC ACID
    This ia 25Kg pack of pure Ortho Boric Acid
    Packed in a heavy dury plastic bag/scak and shipped in sturdy double wall outer box and labelled with appropriate CHIPS III Label
    All products are packd in sturdy outer boxes to ensure safe arrival
    PRODUCT SPECIFICATION TECHNICAL
    Boric Acid % H3BO3: 99.5 min
    Boric Oxide % B2O3: 56.0 min
    Impurities
    Sulphate ppm SO4: 600ppm max
    Chloride ppm Cl: 500ppm max
    Iron Oxide ppm Fe2O3: 4ppm max
    Jonathan
    IG Concrete, tiles and plaster. Pool size: 100M3 (26,417 US Gallons) Sand/Gravel Filter Astor 99 cross section 0.44M2 (4.74 sq. ft.) holds 290 kg (639 lbs) sand/gravel also sometimes with some DE inside. Pacific Sel SWG, Pacific PH Automatic Doser.
    Pump size 1.6HP 24M3/hour (6340 US gal/hour)
    Mar 2007
    San Rafael, CA USA
    12,082
    It's fine to use. A good quality boric acid.
    Quote Originally Posted by Jonathanm
    How is there 99.5 % boric acid and 56 % boric oxide?
    Support the site
    Mar 2007
    San Rafael, CA USA
    12,082
    It's really a synonym of sorts since boric oxide (aka boron trioxide) is an anhydrous form of boric acid:
    H3BO3 --> HBO2 + H2O
    2HBO2 --> B2O3 + H2O
    The molecular weight of B2O3 is 69.6182 g/mole (note the two borons) while boric acid is 61.83 g/mole. So 99.5% * (69.6182/2)/61.83 = 56.0%.
    Mar 2011
    Monaco
    23
    Quote Originally Posted by chem geek
    Thanks for your help - I'll go ahead and get some - I tried several sources in France - ridiculously expensive... It's for sale here in most pharmacies in 30gram sachets - and the chemist told me that its mostly used for killing cockroaches...
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Local Walmart has it for $2.97 box. If you go to customer service they will special order or pull the amount you need. I'll need 14 boxes. Stopped in Saturday, they called Monday they have them. Just got to ask.
    Mar 2007
    San Rafael, CA USA
    12,082
    ... and the chemist told me that its mostly used for killing cockroaches...
    In concentrated form, yes, and you can learn more about why in diluted form it's not a problem for humans, but is for insects in this video. You can read more about borates safety in this thread. The chemist also could have told you that Boric acid is often used in eye wash solutions at around 1% (1750 ppm Boron). For pools and spas, we use only 50 ppm.
    VoR's Avatar
    San Diego, CA
    41
    Home Depot carries it (or at least a year ago they did). I actually had a guy stop me to ask why I was buying 8 boxes of it
    9000 Gallon Gunite Pool
    Pentair 1/2 HP Whisperflo Pump
    Pentair DE Filter
    Kreepy Krauly
    Jun 2015
    Chicago, Ill
    6
    I know this is an old post, but this is the one that is most prevalent in a google search, so I thought I would share my findings here.. 50 lbs of borax for $30.00 Best deal I've been able to find, they shipped the day after I ordered... Shipping was like $13.00 bucks, but still cheaper than I was getting it. Link Below:
    Borax | Bulk Apothecary
    Nov 2015
    Ok ok
    823
    Where to buy borax
    I bought mine from dudadiesel. Bought the boric acid granules so it did not affect my pH. Very clean looking product quick shipping I thought very reasonably priced.
    DudaDiesel - Biodiesel, Chemical & Solar Supplies, Alternative Energy Store
    ~14K gallon - AquaRite AQR15 SWG - pool Newly plastered on April 9 2016
    TF100 kit - STA-RITE SYSTEM3 Modular Media Filtration - Model S8M150
    Pool water supply from on site water well = CH of ~350 and TA of ~350
    Doheny's Discovery Automatic Robotic Cleaner/Pentair Model 011018 VS Pump
    Sundance Altamar Hot tub separate from pool / central Oklahoma
    AstridN's Avatar
    Aug 2016
    Edgewater, Florida
    16
    Does the math on boric acid granulates work the same as with borax?
    Inground fiberglass uncovered 10125 gallon Salt water pool with Semi attached jacuzzi
    aqua rite control system, DE filter, Zodiac Baracuda g2, well water.
    Nov 2015
    Ok ok
    823
    Where to buy borax
    On pool math there is an option to choose granules.
    AstridN's Avatar
    Aug 2016
    Edgewater, Florida
    16
    Thank you!
    I didn't notice that option ��
  20. Back To Top    #20
    JoyfulNoise's Avatar
    May 2015
    13,222
    Boric acid works the same as Borax/MA for adding borates to pool water BUT boric acid is much, much easier to work with and well worth any cost differential. Borax is a strong(ish) base and will raise pH dramatically upon addition. This is why you must add muriatic acid to compensate. Eventually you balance the two but, in the process you create both borate ions in water and lots of excess salt. Boric acid, by contrast, is a weak acid and even with the full 50ppm addition (~40+ lbs for a typical pool volume), the pH will only go down by around 0.3 units. Boric acid also dissolves very rapidly in water and will not cause calcium scale or water cloudiness as borax will.
    You can do the calculations on Pool Math but, roughly speaking, adding the full measure of borates using boric acid lowers the pH by 0.3 units. Adding 1/10 th the amount of borax needed to get to 50ppm raises the pH by nearly 0.9 units and thus requires MA to knock it back down. So, you can add all of the boric acid at once OR you can add the borax in 10 batches with MA additions in between.
    By far, the boric acid method is a lot easier...
    Matt
