Thread: Fiberglass pool how much gravel?
    Oct 2010
    Eastern TN
    172
    My PB recommends a gravel base but the side fill is excavated soil. I am in NC soil is not clay. He can use gravel side fill but it will mean 2-3 loads of gravel at a cost that I seem to remember around 1k. He has been doing these pools in this area for 17 years and provided a response to my question to Trilogy stating that this method is fine. Thoughts?
    Plaster pool inground 22,000 gallons with spa. Pentair Intelliflo, IC40 salt generator, WiFi control/Easy Touch.
    Hayward 1.5 HP pump on 750 gallon spa. Sand filters. Auto chlorinator on spa. Auto water level. Dolphin M500. TF100 XL with Speed Stir. Apera Instruments AI311 PH60 Premium Waterproof pH Pocket Tester
    South Central NJ
    3,192
    Re: Fiberglass pool how much gravel?
    You MUST use either washed in sand or the smallest gravel available. The gently washed in sand and gravel will settle the least, ensuring the walls are provided the support they need. Fill the pool and back fill at the same time, never letting there be more than a foot of difference in height between the two. To do otherwise will result in warped walls, cracks in the gel, or worse.
    The use of spoils (dug out dirt) as back fill will not prevent warped walls and will settle unevenly, resulting in lost support under the concrete apron around the pool.
    That the installer is even suggesting that tells me he needs to be watched like a hawk.
    Ensure the shell is FULLY supported on the ground and level to within 1/4" all the way around before adding water.
    Scott
    Owner of - PoolGuyNJ LLC
    30,431
    What does that mean....I don't understand.
    Dec 2009
    Central Massachusetts
    2,690
    Trilogy makes fiberglass pools. I assume he called the manfacturer, Trilogy.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Sep 2009
    Frederick County, MD
    185
    Though sometimes controversial, Marcus had a pretty informative blog.
    Here is an entry on backfilling ..... http://www.riverpoolsandspas.com/blog/b ... mming-Pool
    Jim
    Southern Frederick County, MD - Leisure Moroccan 38 Fiberglass Pool - 19,800 gallons
    Pentair 1.5 hp 2 speed pump - Cartridge filter - Dolphin robot - TF-100 Test Kit - SWCG
    Oct 2010
    Eastern TN
    172
    Quote Originally Posted by Winger 03
    Thanks for the link. I had read this a while ago but I couldn't remember what he advised. Now I'm really bummed. The last thing that I need is to spend $$$ on a fiberglass pool and have it crack due to poor install. The warranty of the pool is worthless because it excludes settling and if a crack develops due to manufacturing defect they won't warrant it for merchantability. In other words they don't guarantee that the pool will work as a pool.
