Results 1 to 9 of 9
Thread: Got my liquidator up - question
    Aug 2010
    Austin, TX
    200
    No results yet - but it's flowing (3 on the flow meter with the 3/8" mods) at the pump speed I want to run at (about 25-30GPM).
    I have a silly question, and perhaps its the celebration beer clouding my mind....
    How do you fill this thing up? I understand there are visible signs when it runs out of chlorine - but there is only about a gallon of room in the tank when it's running at all times.
    When I need to add 4-6 gallons of chlorine quickly - how? Do I dump it?
    38K Gallons IG, Intelliflow VS-SVRS, 30GPM 24/7, 72sqft DE Filter, Spectralight UV, Jandy C1900 driving Liquid Chlorine and Acid (toys, I know..), Jandy LXi gas heater, Aquacal SQ175 Heatpump, Riverflow Competition swimmer, Jandy automation, Touch and iAqualink, Pebblesheen | The Build
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    Re: Got my liquidator up - question
    how-do-you-fill-your-liquidator-t7082.html
    There's you a link. Love to see some pics of your setup.
    Aug 2010
    Austin, TX
    200
    Quote Originally Posted by woodyp
    http://www.troublefreepool.com/how-do-you-fill-your-liquidator-t7082.html
    Perfect, thanks! Will post pics when it's daylight.
    As I suspected. I guess i can crank up the pump to make the process go faster.
    Aug 2010
    Austin, TX
    200
    Some pics
    Jun 2010
    Glendale, CA
    513
    Nice set up. Looks like you got it filled up.
    I've found once I have 4 gal or so in the Liq - it's better to add 1 gallon a week rather than a full 4 gallon recharge a month. Keeps the output of the LQ a lot more consistent.
    Also - you might want to consider spray painting the body of the LQ or insulating it to cut down on chlorine loss - since it looks to be in full sun (mine is too).
    16K Gal Plaster | Compupool SWG | Intelliflow VF | TF-100
    I installed my liquidator about two weeks ago. Just today, I picked up one of these from Home Depot. Installed it on the inlet side of the unit, shut it off for about an hour with the pump running, and ended up with plenty of room to add a gallon of liquid chlorine and some to spare.
    Austin, TX, 15,000 Gallon, Sand Filter, IG plaster, 8 Gallon Liquidator
    does the Liquidator have a lock to keep kids out?
    24' Round 54" Impulse Ovation AGP, 1.5 HP 2 Spd, 150 Sq Ft. Cartridge Filter, RayPak 130K BTU NG Heater, BBB in full effect!!
    Vist TFT Test Kits --- Visit Pool School ---
    Visit the Pool Calculator
    Aug 2010
    Austin, TX
    200
    No it does not, and in fact a kid commented the other day that it looked like lemonade.
    22,553
    You could rig up something like a hasp and loop, or just get a stainless steel long shackle lock and drill through the lid and flange and lock it that way. A coupler lock would also work. The weak point will be the wire ties used as hinges on the cover.
    Or if locking is required, a safer way would be to go with a peristaltic pump and tank system. They usually have locking caps on them.
