Thread: Hayward Pump on/off switch broke
    irishal's Avatar
    May 2009
    Edmond, OK
    37
    We have an AG pool with a Hayward 2HP pump that has served us well. Unfortunately this year the on/off switch underneath appears to have broken off (my guess is by an over-zealous mower). What are my options here to get the thing turned on.....or should I replace the pump?
    Cheers.
    Alan
    Alan
    30ft AGP
    2hp pump
    TFTestkits ,Pool Calculator, Pool School
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Hayward Pump on/off switch broke
    How handy are you with wires? You can bypass the switch and then just plug the pump in when you want it to run and unplug it when you want to turn it off.
    I'd imagine that you could find a replacement switch and install it or put a weatherproof 'light switch' on the line for the pump.
    Luv& Luk
    -Ted
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    If the pump is still in good shape you should be able to find a switch for it. Google the brand and size of the pump motor to look for the parts.
    If you are thinking about changing the pump anyway you could look into a 2 speed pump. Two speed coupled with a lower hp such as 1 or 3/4 would be a significant energy savings and still have enough power to run the vacuum and filter efficiently.
    Love TFP? Become a
    TFP Supporter!
    irishal's Avatar
    May 2009
    Edmond, OK
    37
    Great suggestion waste.....opened up the pump, hardwired the switch, put all back together and works great!!! With the mechanical timer I have inline, I really didn't need the toggle switch anyway.
    Alan
    30ft AGP
    2hp pump
    Mar 2007
    4,160
    I'm glad you got it fixed so easily
    Now you're on your way to a trouble free season
    Luv& Luk
    -Ted
