Results 1 to 8 of 8
Thread: In floor cleaning system for owner/builder
    Aug 2010
    Charleston, South Carolina
    77
    Does anyone know if its possible to get in floor cleaning plans like Paramount PCC2000 without going through a dealer? I'm not trying to step on any toes and I understand the benefits of having an experienced, "certified" dealer do the installation. BUT....I was just wondering if it's possible to get Paramount to design the system and I buy the parts online and do the installation myself. Again, I'm not trying to say that it's so easy a caveman can do it. I'm just asking the question!
    Thanks in advance.
    half Inground/half above ground, shotcrete pool, 19,000 gallons - KrystalKrete Krystal Blue quartz finish
    Pentair intelliflo variable speed pump - Pentair Easy Touch automation - Pentair T100 sand filter - Savi Melody LED lights - Mortex KoolDeck - Charleston, South Carolina
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: In floor cleaning system for owner/builder
    I dunno. You can buy all the parts easily enough, but it would be a huge pain to install.
    A more pointed question: why bother? I have an in-floor system and wish I did not. For far less money and hassle you can build it normally, buy the best robot on the market, and have a much more effective/efficient cleaner to boot!
    SCEADU's Avatar
    Feb 2010
    Atlanta,GA
    68
    The PCCC is typically anly offered to registered builders. Paramount only allows a small number of builders in an area to install the PCCC. I am not sure about their other models.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP!!
    I used to install the Caretaker (tm) system and agree with MITS on the utility of them. However, you could always go with a few in floor returns to gain the heating and chemical distribution effects
    Luv& Luk
    -Ted
    Woodberg's Avatar
    Apr 2009
    Houston, TX (Candlelight Estates)
    136
    I don't know if you could put it in yourself, but I would highly recommend the PCC-2000 system. We have a two year old pool with the PCC-2000 system and its done a great job keeping the pool clean. The pool stays free of debris and I just dump out skimmer baskets. Its also good for circulating the water, especially when adding chemicals. A good friend has the Paramount Pool Valet and also says it does a great job. I don't know much about other brands of in-floor systems, but in my experience, I would never put in a pool without one.
    20,000 gallon gunite pool, attached spa, Pebblesheen finish, Paramount PCC-2000 infloor cleaning system, Paramount ClearO3 ozone system, Intelliflo VS main pump, Whisperflo 1HP cleaner pump, StaRite cartridge filter, StaRite heater
    Quote Originally Posted by Woodberg
    This^. We have a Paramount infloorand I love it! Would not build a pool without one. They seem to get a bad rap around here but I love mine.
    Kurt R
    35900 gal. 20x40 Inground, Vinyl Liner with Deep End in the Middle, Roman Stairs on Both Ends
    Sta Rite Sys 3, Hayward 1.5 Super Pump, Aqua Heat Heat Pump, Paramount in Floor, BBB
    Every pool I service that has an in-floor cleaning system ONLY, doesn't work worth beans. I bid extra whenever I see one of these. Great circulation, but dead cleaning spots and the need for BIG pumps. What I dislike about them even more, is (on most) this was the ONLY return system put in, so at no point in the future can I plug in a pressure-side sweep. If you don't want to save your money, try http://www.infloorpoolparts.com/.
    I know they work well in a few cases, but I really don't like them... (Can ya tell? ).
    ~45Kg Pool with attached Spa, NSP-72 DE, Minmax 400 Heater, Tahoe Blue Pebbletech, Jandy SWG via Aqualink RS-8, The Pool Cleaner (black)
    Pumps: X3 Hybrid Pump (switches to SPA), 2HP Spa (additional, when SPA is on), and a 1HP For Waterfall
    8, 4x12 Solar Panels on the roof of the pool-house (~12' up)
    CAPTAIN JAMES T. KIRK: "I'M SORRY. I CAN'T HEAR YOU OVER THE SOUND OF HOW AWESOME I AM" (Thanks to TFP!)
    Mar 2007
    4,160
    Even with an infloor cleaner, you should have a couple regular returns to provide surface circulation to help the skimmers
    Luv& Luk
    -Ted
