Page 1 of 2 12 LastLast
Results 1 to 20 of 32
Thread: I can't shock my pool
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,966
    I need to shock my pool.
    I plugged in a blow dryer and dropped it in. Nothing. Next I tried a toaster. Nothing has changed.
    Do I need something that's 220 volts?
    April Fools!!
    dmanb2b's Avatar
    Apr 2009
    NY
    3,728
    Re: I can't shock my pool
    N1 Richard
    Did you remember to defeat the GFI first?
    crookm11's Avatar
    Jun 2010
    Copperas Cove, Texas
    422
    Remember Shocking a pool is a process!!! So you would have to use both the blow dryer and the toaster at the same time!!! Didn't we teach you anything.
    Mark Crook
    13,500 Gallon 24' x 52" Intex Ultra Frame
    Intex Sand Filter and Pump, Intex SWG (All hard PVC plumbed)
    TFTestKit-100---Pool School---The Pool Calculator
    Location: Copperas Cove, Texas --- My Pool Build---Useful Links for Intex Pool Owners
    Mar 2010
    Spring, TX
    1,082
    Did you try your TV or Laptop/Desktop?
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Apr 2010
    Buckeye, AZ 85326
    619
    Hahaha, You'll never know if you are truely shocking unless you get a good quality test kit. May I suggest the TFTestKit/volt meter......
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    Aug 2007
    near the swamp
    806
    I've always wanted to know if that would kill algea or not.
    Jun 2010
    Glendale, CA
    513
    Call these guys - if they are still alive...
    16K Gal Plaster | Compupool SWG | Intelliflow VF | TF-100
    dmanb2b's Avatar
    Apr 2009
    NY
    3,728
    Quote Originally Posted by lightingguy
    Wonder how they bonded that intex pool
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,552
    My pool crew is all pretty UGGGGGGGGGGGGly. We'll come over and shock it for ya'.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,374
    Richard, you need the proper materials to shock with. A toaster wouldn't shock a goldfish bowl! What you need to do is go to Best Buy and get the largest 3D television they have and pay cash for it. Take it home, tune in to "Oprah" and chuck it in the deep end! (Be sure to wear the 3D glasses for optimum effect!)
    Love TFP? Become a
    TFP Supporter!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Richard you need more volts and more importantly you need more amps. You could try going to your local generator rental place and get the biggest trailer mounted generator they have, .....
    guamguy's Avatar
    Feb 2010
    Guam, USA
    388
    If you've got any overhead high-voltage power lines around, you could get a long metal chain, put one end in the pool, and throw the other end over the power line. That should give the pool a good shock
    12,800 gallon IG plaster kidney-shaped pool, waterslide, 800 gallon spa.
    1HP 2 speed Sta-Rite pool pump, 1.5 HP Sta-Rite spa jet pump. 2 skimmers, 1 main drain
    Purex-Triton TR-60 325 lb.sand filter. 2" Plumbing, Intex SWCG, TF-100 test kit.
    Link to pics of my pool! http://www.troublefreepool.com/my-oasis-t26558.html
    Sep 2010
    SC Lowcountry
    54
    Not enough jiggawatts. Refuel your Flux Capacitor. Jeez
    Viking Laguna 14K IG , Smart Pure SWCG, SwimClear C5520 Cartridge Filter, TriStar 1.5HP, SmartControl PLP4 controller.
    Lana537's Avatar
    May 2009
    The Triangle, NC
    242
    Dearest colleagues~~
    This is the best thread ever! thank you!
    LOL!
    Lana
    23,600 gallon, refurbished 1960's inground concrete, Jandy sand filter w Jandy 2 hp variable speed pump, Pool Pilot Digital SWCG+Chemtrol 2100+CO2 tank; PebbleTec White Pearl with 10% Cobalt Blue Dark Beadcrete by Olympic Pool Plastering, Georgia. Taylor K-2006 Test Kit; Aqua Check Salt test; LaMotte borates test, and Jack's Magic Sequest test kit; SparklyPoolitis level: extremely high.
    South Central NJ
    3,192
    Shocking is a process:
    Voltage doesn't kill, amperage does.
    In order to pass enough current, add a few extra bags of salt first.
    Then drop the the ground clamp of a Lincon Arc welder in the water.
    (Hint)If you go to a boating store, you can get a couple large zinc anodes and put one on the ground clamp and one on the stinger.
    Drop in the water and crank up the amperage to 225 amps.
    Turn on the the welder.
    This will quickly toast any biologicals in the water, even chlorine resistant crypto and gardia.
    Scott
    Owner of - PoolGuyNJ LLC
    Oh..... this thread was great. I needed a good laugh. This week hasn't been good.
    Here's to the weekend coming up
    Lol, thought it was an interesting subject until reading the thread.... It's even more interesting..... Haa nice going guys, hilarious. Thanks for all that you do!
    Jovian, Pool owner since 2011
    Specs: 30k Gallons, Sand Filter, IG, Vinyl, Filter: Hayward S244T, Pump: Hayward 1.5 HP SP2610X15
    Apr 2011
    Somewhere on the Emerald Coast
    156
    In my best James Bond (Sean Connery) voice ... from Thunderball for all you pup's ...
    .... Shocking!
    20,125 gal. (2,690.6 c.f.) In-Ground / Concrete (Gunite) / Pentair Tagelus TA-60-60D Sand Filter / Pentair Whisper Flo Pump Model WF-24 @ 1HP / Hayward Veri-Flo Valve Model 710 / Taylor FAS-DPD K-2006 test kit / Pool School student
  20. Back To Top    #20
    Richard320's Avatar
    Jan 2010
    18,966
    Bump
