Thread: Does it matter if you plaster on a hot day?
    Jan 2011
    Riverside, CA
    352
    The guys are scheduled to plaster tomorrow. The forecast is about 90 by 2 pm. Forecast for Saturday is a high of 76.
    Does it matter if they guys plaster on a warm day? Should anything be done differently?
    Plaster is a Mini-Pebble, similar to Pebble Sheen, if that makes a difference.
    Thanks.
    40x20 Free Form IG Pool (aprox 29,000 Gal, 140 Perimeter, depth 3'6"-7', Baja Shelf, 8x8 Free Form Spa) - Gunite Shell, Pebble Plaster Finish, Poured Concrete Coping - 3 Deep Heat Returns - Jandy LXi400 Gas Heater (400,000 Btu) - Jandy Variable Speed Pump JEP 2.0 - Jandy CL 600 Filter - HASA Liquidator - Jandy PDA 6 w/ Remote - 4x Jandy WaterColors Pool LEDs - 48" Gas Fire Pit - 6x Gas Tiki Torches - 12'x15' U-shaped BBQ Island (Firemagic Equipment)
    http://www.troublefreepool.com/new-p...ca-t28413.html
    Apr 2010
    Buckeye, AZ 85326
    619
    Re: Does it matter if you plaster on a hot day?
    I bet you are excited ! It was 100*+ when they did our pebble so you should have no problems .
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    30,414
    I think the short answer is it DOES matter somewhat. Good plasterers will take precautions on a hot day that the material doesn't dry and set up too quickly. I would bring up the subject with the plasterer and gauge his reaction.
    That's a cool weather site....mind sharing the url?
    guamguy's Avatar
    Feb 2010
    Guam, USA
    388
    12,800 gallon IG plaster kidney-shaped pool, waterslide, 800 gallon spa.
    1HP 2 speed Sta-Rite pool pump, 1.5 HP Sta-Rite spa jet pump. 2 skimmers, 1 main drain
    Purex-Triton TR-60 325 lb.sand filter. 2" Plumbing, Intex SWCG, TF-100 test kit.
    Link to pics of my pool! http://www.troublefreepool.com/my-oasis-t26558.html
    90+ is no problem for a plaster crew that has any experience. What you absolutely don't want is rain while the plaster is being applied or for about the next hour or two.
    Jan 2011
    Riverside, CA
    352
    Yea, Weather Underground. It has much more detail than Weather.com
    They are mixing stuff right now
