Thread: What replacement filters do I need?
    I have these Pentair filters that I'm thinking I need to replace. I don't know how old they are or how often they need replacement, but I think the previous owner probably never swapped them out in their entire lives.
    I see a bunch of different P/N's on them, but I don't know which I have. I'm guess they are the P/N that is set aside by itself, the 130 Sq. Ft. ones. Am I right? Here they are. Also, what is a good vaccuum thing to get? As of now I've been stealing my dads every couple weeks.
    18,000 Gallons plaster, in ground. Pentair quad cartridge filter system charged w/DE. Built in the early 70's. Location: Bakersfield California. Summer temps from early May to late September, up into the 100'sF. Very low shade over pool, not until LATE evening. Palm tree drops pods from neighbors yard.
    Oct 2010
    Georgia
    317
    Re: What replacement filters do I need?
    Looks like a Pentair clean and clear plus quad filter.
    The filter uses the same manifold (top assembly) for several different models.
    See if you can locate a tag or label on the outside of the tank that lists the model number and a year it was built.
    poolschoolgrad
    20x40 free-form IG vinyl, 1hp Hayward superpump, Hayward pro grid DE filter, Raypak heatpump, Goldline Aquarite SWCG, Polaris 280 with booster, and tested using a Taylor K2006.
    Sadly, this is all that remains. It is indeed a quad cartridge clean and clear system. Thing is, which cartridges. They ARE about 32 inches long as one of the measurements states (not in previous images, but is on cartridges) so I'm guessing that each cartridge is the 130 sq ft. NOT the lesser sq. footage ones listed. Do you all agree with my assesment?
    Oct 2010
    Georgia
    317
    Measurements for each individual 130 sq ft filter are 7" x 32 1/16"
    Hole size is 3"
    After market replacement filters:
    Filbur # FC-1978
    Pleatco # PCC130
    Unicel # C-7472
    OEM # R173578
    Hope this helps
    poolschoolgrad
    Feb 2008
    Denton, TX
    5,061
    I bought a set of Pleatco carts for my CC320P filter a couple of years ago. They have been great.
    Mar 2011
    Lower Bucks County,PA
    65
    http://www.allpoolcartridges.com/pool-f ... idges.aspx
    Found that this comes in handy, just passing it on.
    12X24 Oval AGP +/- 7100 gal
    Clearwater 100 cartridge filter
    Hi-Flo 2sp 1hp pump
