Results 1 to 19 of 19
Thread: Should I fill new pool from hydrant or hose from house
    Feb 2011
    Cincinnati, Ohio
    106
    I was just wondering when my pool is done is it ok to fill from a hydrant or should I use tap water from my house? Obviously the hydrant would be great but I wasn't sure if filling it too fast could be an issue or if sometimes the water in hydrants causes an issue.
    18 x 36 IG Vinyl Liner 28K Gallons
    Pentair Intelliflo VS+SVRS, Pentair CC + 420 Cartridge Filter, Easytouch CP with IC40 SWG
    2" Suction and Return Lines - 2 skimmers, 6 returns
    Dolphin Diagnostic Advantage Robot
    Nov 2010
    Calera, Al
    271
    Re: Should I fill new pool from hydrant or hose from house
    They would need to flush the hydrant first, but it will fill much quicker than with a hose.
    17,000 gal, IG Gunite Diamond Brite plaster Kidneybean,w/7x11 tanning ledge& 3x5 swimout bench,244T 300lb Hayward Pro high rate sand filter(63 GPM) , Hayward 1Hp Super Pump w/3/4 hp booster pump, Polaris 280, Laars Lite 2 175k N/G Heater, Tf-100, Speed stir
    Jul 2009
    Northern California
    20
    I asked my PB to fill my pool with the hydrant and was told that the pressure from the hydrant would mess up the new plaster. They even wrapped a rag around the end of the hoses to reduce the output.
    I gave my neighbor some cash and some baked goods, and borrowed his hose.
    15,000Gal IG Gunite\Color Quartz Plaster
    Jandy CL460 Cart Filter (460sqft, 150GPM)
    Hayward EcoStar SP3400VSP
    AquaPure 1400 SWG
    Apr 2010
    Buckeye, AZ 85326
    619
    I talked to a buddy who is a fireman when we filled up my pool and he said they would need to flush the hydrant, then I would need to get a meter to see how much water I used. The logistics seemed like more trouble than it was worth. I put a "y" on one of my bibs so I could use 2 hoses and used another hose bib from the front of the house for a total of 3 hoses. My pool filled up really fast, about 10 hours for about 12k gallons.
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    30,411
    Brian,
    How big is your pool?
    Feb 2008
    Denton, TX
    5,061
    Some people have been known to fill wih a hydrant. The main thing is to make sure that you have permission from the city/FD/water department to do so lest you get hit with a fine.
    Feb 2011
    Cincinnati, Ohio
    106
    18x36 with 8' deep end. I think around 24K gal
    Would the higher pressure of the hydrant hurt the liner? Or would the quick fill and weight hurt the liner vs a gradual fill
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    If you are not in a rush and your home water supply is not very expensive and the water quality is decent (no metals and no high CH), I would recommend filling it from your home supply. It will likely take 2 days to fill it up, but will be very gentle in terms of setting/stretching the liner.
    That's just me...but then again, many folks fill their pools via trucked in water and they dump 3-4k gallons at a time in a matter of 10 mins or so
    30,411
    Filling a 24k pool with the hose (while probably the best) might get a little tedious. On city water pressure, you would likely get around 8gpm out of the hose, 5 if your on a well. So 24k @ 8gpm = 50 hours.
    That said, the big advantage is you can test your tap water prior to putting it in the pool and be ready to balance it as it fills.
    You can easily work around any disadvantages of high pressure by simply using boards to deflect the flow.
    Have you calculated both costs?
    Feb 2011
    Cincinnati, Ohio
    106
    probably same cost either way. city has a guage that will go on my hose so i don't pay sewage. if costs doesnt matter should i just use tap water
    30,411
    I would say yes. It allows you to test the tap water and be assured of the quality as it goes in.
    Mar 2009
    Charlotte, NC
    539
    Quote Originally Posted by briansturgeon
    Can you or anyone elaborate?
    Thanks
    19,800 gallons (closed/winter 18,654 gal); plaster; 18x34 Ft kidney bean shape, Depth 3Ft-5Ft. Built 1992
    Pentair Whisper Flow Pump 1HP. Winter safety cover w anchors.
    Sand filter, Pentair Sand Dollar Top Mount Model SD80; Effective Filtration Area 3.5SF
    - FlowRate 75GPM, 8Hr 36,000, 10Hr 45,000, 12Hr 54,000; Pressure Weight 50PSI
    BBB (Hayward Chlorinator when leave town). Polaris 360 cleaner.
    carlos31820's Avatar
    Nov 2010
    Midland, Georgia
    353
    Some cities will let you fill the pool and not charge sewer fees. However, they let you borrow a temporary meter that connects to the hose. This way they know how much to adjust the water bill.
    16x36 Vinyl Pool - 22.5K gallons.
    Jandy Stealth 1hp pump - Jandy CS-150 filter
    Jandy Legacy 250k heater - Jandy Ei SWCG
    Jandy Watercolors LED light
    Paramount Vanquish in-floor cleaner
    Feb 2011
    Cincinnati, Ohio
    106
    My city sells you a $50 meter for your garden hose that you can use for filling topping off the pool and then at the end of summer you turn in the readings and they will credit me for the overage I paid on the sewer based on those readings. It is amazing to me that on my bill sewage actually costs more than my water.
    I've done mine with a regular old fire house (a couple of times now) and it filled up in about 20 hours. Definitely do-able and probably cheaper over all than the hydrant or truck method.
    Clearwater, Florida
    12,000 gallon kidney shaped gunite pool
    Pentair Whisperflo 3/4HP Pump
    Pentair CCP420 420sq/ft Cartridge Filter
    Pentair Intellibrite 5G 120V Pool Light
    Mar 2007
    Coastalish 'down easter'
    4,160
    If, for whatever reason, someone wants to fill a liner pool with a truck or via the fire hydrant, there is a risk of wrinkling (not, per se. damaging) the liner if the flow is not deflected!
    I think I've given the caveats elsewhere, but a quick search didn't locate them for me - if you want the info, just ask and I'll either dig deeper into the archives or repeat my advice
    Luv& Luk
    -Ted
    Feb 2011
    Cincinnati, Ohio
    106
    waste, could you please elaborate or dig deeper
    thanks
    Mar 2007
    4,160
    I still can't find the post
    Oh well here's what to do and look out for:
    Run the hose to the deep end corner (a lot of water truck drivers will try to fill at the closest point, make the lazy *** put on another length of hose ).
    Start the flow slowly and have someone holding and aiming the flow (to make sure the hose doesn't 'snake' around and that all the connect5ions/ hoses aren't leaking. The person holding the hose should aim the flow at a wall to deflect the force and it helps if they cup their fingers over the flow to further deflect the force.
    Once you've got ~ 6" in the hopper, kill the flow and install the MD faceplates, cut out the liner and install the covers.
    Start it back up, as before.
    Once you've got a couple feet of water in the hopper, direct the flow into the center of the hopper.
    The reason for deflecting the flow off a deep end wall is to prevent floor wrinkles. If you just let it go into the shallow end the force of the water can wrinkle the shallow end floor and/ or the slope (try to imagine the force of 300 gal./ min. )
    I'm not saying that you are guaranteed to get wrinkles if you fill from the shallow end, but why risk it?
    Luv& Luk
    -Ted
    Aug 2010
    Dallas, TX
    4,052
    Quote Originally Posted by carlos31820
    At my house I have 2 meters on two separate mains. One for the house that gets sewer charges, one for the pool and irrigation with no sewer charges. Really saves a lot of money.
