Thread: Pool has become brown and filled with murky water
    I am new at this pool thing and also enjoyed our pool from our new house last summer. This winter the pool has become brown and filled with murky water, leaves and some trash. What do I need to do to get it ready for go for summer use again? It is an above ground pool and the filter and pump have been outside all winter.
    Pool Capacity - 17,000+/-,Sand Filter on IG plaster style older build, pump size TBD
    Free eBook! ---> Internet Safety Tips - "The Essentials" ---> The Seeber Consulting Blog
    22,544
    Re: Pool has become brown and filled with murky water
    Welcome to TFP.
    The first thing you need to do is make sure the equipment will work and isn't leaking.
    Then you need to scoop as much of the debris out as possible.
    Then read the article on turning-your-green-swamp-back-into-a-sparking-oasis. And read all the articles in Pool School on defeating algae.
    That'll get you started. Oh, and go ahead and order you a good Test Kit and Speedstir. (speedstir optional, test kit not!)
