Results 1 to 8 of 8
Thread: I have another question about pebble tec
    I have pebble tec on my tanning ledge that I do not like. I want to overlay it and was wondering if I could use a colored portland cement to overlay the pebble tec.
    Thanks again.
    14,500 gal pool
    Inground
    Intellichlor Salt Generator
    Water Fall
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: I have another question about pebble tec
    Never heard of anyone wanting to do that. What's the problem with the pebble tec?
    If you wanted to get rid of it, the proper way would be to chip it out and do a proper plaster job. Any chance of some photos?
    The PebbleTec could be covered over, though it will be tricky to get a good enough bond. To get that bond to work the current surface needs to be carefully cleaned, you will need to use a bonding agent, and the new layer has to have some thickness so it doesn't just flake off. Chipping out and then applying plaster would be more reliable.
    Photos
    It is ugly, it doesn't match and it is rough on the edges.
    14,500 gal pool
    Inground
    Water Fall
    ThePoolNinja's Avatar
    Apr 2011
    Southern California
    61
    How old is that Pebble Tec?
    South Central NJ
    3,192
    Ad how many time has it been acid washed with straight muriatic? WOW!
    Scott
    Owner of - PoolGuyNJ LLC
    Quote Originally Posted by ThePoolNinja
    It is about 4 yrs old
    14,500 gal pool
    Inground
    Water Fall
    Quote Originally Posted by PoolGuyNJ
    Scott
    It has been acid washed a few times but not with pure acid
    14,500 gal pool
    Inground
    Water Fall
