Results 1 to 7 of 7
Thread: Transition to BBB from Perm A Salt
    We have had the AG in my signature for 2 seasons and this will be the 3rd season. I have always been concerned about the " Perm a Salt" System based off information I was reading on various Forums but my water has always been Clear and without Issue. I have decided to transition to the BBB Method so I ordered my TF100 which was received yesterday. I performed my First Tests this morning (results below). I removed the cover last week and the water had a green tint to it so I did add some Bleach and started the Pump, keep in mind this was done prior to testing this morning. I did plug my numbers into the pool calculator but am a little confused on what my next steps should be?
    Any Advice or suggestions would be greatly appreciated.
    Borate- 80 or greater ????
    FC-2
    CC-.5
    TC-2.5
    PH-7.5
    TA-90
    CL-.5 to 1
    CYA- Less than 20
    Temp- 55
    27'x54" AGP (19,500 Gallons)
    Eco Kleer 200 sq ft Cartridge Filter
    1.5 hp Eco Kleer Pump
    Middle TN
    22,553
    Re: Transition to BBB from Perm A Salt
    Welcome to TFP.
    Given that you have a CC of .5 after the cover has been off a week I would do an OCLT (overnight chlorine loss test).
    If you fail that you need to shock the pool and finish getting rid of the algae.
    If you pass it then I'd raise the FC to about 4 ppm to see if that'll take care of it.
    Then I'd raise the CYA to about 40 ppm.
    What is your CH?
    Perma Salt adds copper and silver to the water. Before adding too much chlorine you should get the water tested for copper. If the copper level is above 0.3 you need to be very very careful with the PH until you get the copper level down.
    How do I go about Testing the copper Level? I do not see anything in my TF100 to do so , I assume I will need to either buy something additional or take it to a pool store for testing.
    Middle TN
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    A good pool store should be able to test it for you
    Ok - so I took a sample to a local Pool Store for Testing this morning and results are as follows.
    FC- 0
    TC-.9
    CC-.9
    ph- 7.7
    Hardnes- 62
    Alkalinity-47
    Cyanuric Acid- 8
    ***Copper-0*****
    The Employee of this Pool Store was very helpful, Tested the water for free even after I indicated that I wouldn't be buying any chemicals. He stated that he was not Knowledgeable about BBB but certainly didn't attempt to sale me on anything else.
    My Alkalinity and CYA seem to be low. I did not run the the OCLT yest as I wanted to get the water tested for copper before proceeding. Other than the OCLT as suggested above any additional thoughts or suggestions for next steps?
    Thanks
    Middle TN
    Good, no problems with copper to worry about.
    Yes, your CYA level is a little low. I suggest adding enough CYA to raise it up to around 40 ppm.
    You should be adding about 2 ppm of chlorine every evening until CYA starts coming up more.
    I'm less sure of your TA level. The first set of test results you posted showed TA at 90, and I doubt that it would have fallen that much. One or the other test result is probably wrong. When your TF100 shows up we will have a better idea of what to do.
