Thread: sand filter question
    I have a haward sand filter. I do not know how old it is other than they do not make it anymore and it does not have laterals like the newer models. It has some type of circular grid in the bottom. My question is how do you know when it is time to replace the entire filter and not just the sand. The pressure still seems to rise normally, but I do not know if it is filtering properly.
    24'ag, 1hp hayward powerflo, sand filter
    22,551
    Re: sand filter question
    The filtering is done by the sand, so unless something in the filter is broken and leaking or bypassing sand, it doesn't need replacing.
    If anything ever breaks you'll probably have to replace it, simply because you won't be able to find parts for it.
    so, if an internal part is broken it would be blowing sand back into the pool?
    Nov 2010
    152
    yes, you would normally see "lines" of sand accumulating directly under the return jets, with sand in other areas as well. If you have an automatic pool cleaner, turn it off for a couple of days, backwash the filter & watch the floor for 48 hours. If something's broken inside, you'll see very distinct lines of sand build up on the floor since the sand is heavier than the water, it tends to settle to the floor very quickly.
    APSP CST Certified
    17k inground concrete; 1.5hp 2 speed Tristar pump, 300sq.ft. Cartridge filter, AquaLogic PS-4 w/ Tcell-15, Navigator suction cleaner.
    22,551
    It could be blowing sand back into the pool. Depending on your particular setup there are things that could happen that could allow water to bypass the sand and be returned to the pool unfiltered. But that's not likely.
    Does your filter have a slide valve or a multiport?
    Jul 2009
    London and France
    574
    Quote Originally Posted by Ranger987
    Just like to add; don't forget the rinse after backwashing or you may get some dirt or sand that you think is from an internal leak.
