Results 1 to 7 of 7
Thread: Do Hayward Pro Series Filters have a spider gasket?
    Mar 2007
    Ontario
    211
    Hi,
    I don't see a spider gasket on the parts list in my manual. Its a s-210T model.
    When I drained my solar last fall I found filter sand at the end of the run in the header.
    Also on the steps below the return.
    I figured the spider gasket would be a good place to start.
    Thanks for any information.
    16x32 inground vinyl 8' deep end
    1hp Northstar Pump, 20" Sand Filter
    6ft Double Lounge, 2 Aqua Lamps w/remote
    216sqft Sungrabber Panels (9- 2'x12') a little undersized
    Re: Do Hayward Pro Series Filters have a spider gasket?
    A spider gasket is part of a multi-port main valve, not really part of the filter. If you have a push/pull main valve then you don't have a spider gasket.
    Sand coming out of the filter would not be a spider gasket issue. DE getting out can happen because of a bad spider gasket, but sand leaking out is nearly always a problem inside the filter.
    Mar 2007
    Ontario
    211
    Thanks for the reply! Now I am thinking I should check the laterals for a crack.
    Does that make sense? When I loosen the flange clamp does the valve just lift straight up
    off the centre pipe?
    Thanks
    Aug 2007
    near the swamp
    806
    Yes.
    Mar 2007
    Ontario
    211
    I just took out all the sand and checked the up pipe and the laterals for cracks.
    I don't see any cracks. Is there a secret to getting the up pipe centered when
    I put the sand back in?
    Where else could the sand be getting through to the return on my steps and in my solar
    headers?
    Thanks in advance
    solarboy's Avatar
    Aug 2010
    Europe
    337
    I have a filter without a centering ring for the upright tube. How I got round this was to put just enough sand in the bottom that I could move the upright tube around, but it would stay where it was left. Then I fitted the valve in position, then took it back off with the upright now in position. Then I carefully filled up the filter with sand without disturbing the upright. Was easy.
    Self built 5500 gallon bare concrete (temporarily) pool with limestone coping, Pentair Swimmey 1/2 HP pump, Triton sand filter with DE, Simpool peristaltic muriatic acid pump with pH sensor and Monarch SWG. Home made solar heater with Pentair Compool control panel and 3 way valve. 1 skimmer, 1 main drain, 2 returns, 2" plumbing, Hayward auto fill valve.
    Mar 2007
    Ontario
    211
    Thanks that makes sense. Does anybody have an idea where the sand would be getting through?
    Some say maybe spider gasket is that possible?
    Thanks
