Thread: How important is SVRS? In particular on a pump.
    Puffin's Avatar
    Jul 2010
    Metro Atlanta, Georgia
    217
    Looking at the Ecostar and Intelliflo pumps I see they both have SVRS options. This option raises the price by about 25%-35%. I don't recall seeing this feature on (many, if any) single and 2 speed pumps. So I've been wondering, how important is this feature? Is it worth the extra money?
    19,600 gal, Vinyl, Grecian L, StaRite Dura-Glas 1 HP pump, 3/4hp booster, Pentair Clean and Clear 420 Cartridge filter
    The Pool Cleaner 4x, PoolSkim
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: How important is SVRS? In particular on a pump.
    Others may correct me, but my impression is that if your pool was constructed with dual main drains and/or has the entrapment-proof covers, it is unnecessary. It's designed to release the suction if it senses that something is stuck in the suction port (i.e. a child's swimsuit). An older pool with a single drain would benefit, but should be retrofitted with the entrapment-proof drain cover anyway.
    SVRS is well worth it if you have to have it, and should generally be avoided otherwise. As Melt In The Sun said, you only need it if your drain/suction ports are not otherwise entrapment proof.
    South Central NJ
    3,192
    Some states/towns require them on new construction. Suffolk county on Long Island (NY) requires them and not just on commercial pools.
    They can help make a pool safer, even if they have dual, non blockable drains.
    There are two in the US market that are available today. The Hayward and the Pentair. I am not a fan of Hayward in general but some here are. The Pentair has been out substantially longer. The Hayward is, in this category, the new kid on the block.
    Scott
    Owner of - PoolGuyNJ LLC
    Aug 2010
    Austin, TX
    200
    I have it on the vs-SVRS and it's bloody annoying. It's like princess and the pea, the pump stops when you get any air into the system - like when vacuuming. If you don't need the LCD display, the VS-3050 is the way to go if you want a 3HP unit.
    38K Gallons IG, Intelliflow VS-SVRS, 30GPM 24/7, 72sqft DE Filter, Spectralight UV, Jandy C1900 driving Liquid Chlorine and Acid (toys, I know..), Jandy LXi gas heater, Aquacal SQ175 Heatpump, Riverflow Competition swimmer, Jandy automation, Touch and iAqualink, Pebblesheen | The Build
