Thread: Replacing widemouth skimmer
    Mar 2011
    Lower Bucks County,PA
    65
    Have a 12 year old generic W/M that i want to replace with a Hayward sp1090wm. Specs look almost identical +/- 1/8. Is this a common retrofit swapout? And would anyone know the difference between a sp1090wm and a sp1091wm? Thanks in advance.
    12X24 Oval AGP +/- 7100 gal
    Clearwater 100 cartridge filter
    Hi-Flo 2sp 1hp pump
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,414
    Re: Replacing widemouth skimmer
    Sorry, I don't know anything about the specs of the skimmers you are looking at, but I do have a couple of questions.
    Is this for an above ground or in ground pool?
    If in ground what materials are the decking, and the pool surface?
    Love TFP? Become a
    TFP Supporter!
    Mar 2011
    65
    Sorry, Ag, Found that the 91wm replaces 90wm model.
    Hi-Flo 2sp 1hp pump
    Jul 2009
    Houston, Texas
    9,414
    As long as the opening is the same size it shouldn't be a problem. You will want to get a new set of gaskets for the opening if the skimmer doesn't come with them.
    Love TFP? Become a
    TFP Supporter!
