Thread: My pool has new plaster
    Jan 2008
    Dallas TX
    20
    Hi all,
    I just finished renovating my pool - new plaster (with pebbles in it) and new tiles.
    It is currently being filled out with water.
    As fas a chemistry - what should I put there? how much CYA.
    I have 15k gallon pool.
    Thanks for your answers !!!!
    My pools info:
    IG concrete pool, 15000G, DE, iRobot Verro, Located in DFW area.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: My pool has new plaster
    There's a pool school article about starting up with new plaster here:
    pool-school/pool_plaster_start-up
    If you have further questions, feel free to ask
    We always love pictures too...
    Jan 2008
    Dallas TX
    20
    I have only one question - what is sequestrant ?
    My pools info:
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    From a previous post
    It keeps metals in the water in solution so they don't stain. Warranties don't cover staining and enough people have metals in their water and they've had enough complaints that it's become a standard recommendation.
    As I said, if you don't have metals then it's a useless expense.
    Feb 2008
    Denton, TX
    5,061
    Typically, as long as you are on municipal water and are not using a well, metals are not an issue and you don't need sequestrant. If you are worried about metals and metal staining though, you can easily take a water sample up to the pool store and have them test it for you.
    If you are on Dallas' municipal water, you won't need a sequestrant.
