Thanks Mark, I'll check those out.
I just looked at the Blue-White F-300 Flowmeter for 1 1/2" pvc and they require 10x the pipe diam. of straight horizontal pipe leading in to the meter and 4x pipe diam. after as their minimum acceptable dimensions. Unfortunately, I only have a 12" straight section (right after the IC-40), a 90 deg. elbow and an 11" straight section before it turns another 90 deg. and goes down into the ground. I imagine there would be too much turbulence to get an accurate reading with the setup I've got. Are you aware of any other types of flowmeters that might work with my configuration?
