Page 1 of 3 123 LastLast
Results 1 to 20 of 56
Thread: Intro and build pics, above ground sunk w/retaining wall
    Here is my project. If anyone sees any problems please let me know.
    This is a 15' x 48" pool with 1.5hp pump w/ sand filter.
    The plan is to be 2 steps down to the pool level from my patio. And then level with the lower patio grade. There is a retaining wall around the rear of the property so drainage is not really an issue since its lower back there than the pool.
    I put a drain in on the outside of the pool wall near the skimmer this should take out any water that gets around the pool. I plan to fill with gravel up to near the level of the drain and then put a layer of concrete around the pool wall and in between the reataining wall that is around the pool. this will be graded to take all the water that gets in between the walls out to the drain that runs to the drainage that runs out the back of the yard.
    I plan on building a round deck from the pool to 15" out away from the pool wall So that I can change the liner if needed and access all the parts on the pool. I plan to have a plywood floor on the deck covered in backerboard and then slate on top of that.
    I just filled in the dirt up to the wall the yard used to start going down right at the end of the patio. Now it has been dug back out.
    Here is the plan:
    Uploaded with ImageShack.us
    Re: Intro and build pics, above ground sunk w/retaining wall
    I damaged the pool liner beyond repair so a new liner is in now (not pictured yet) but that is why the water is drained. I had an aurora LED light in it, but the light leaked and shorted out. When removing I tore the liner at the return. I tried to patch it, but it just got worse. I ended up with a 4" x 6" hole in the liner at the return(as seen in last pic at bottom of this post).
    JoshU's Avatar
    New Orleans, LA
    542
    That is quite a project you have going on there. Keep us posted and welcome to TFP.
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
    Guest
    WOW, you certainly do not lack ambition! I can't wait to see the finished product, keep taking pics and posting the progress.
    Here it is with the new liner
    Also I put in a few posts for extra support. They will be cut off even with the pool.
    Its been raining alot latley and its too muddy to get the gravel I need, but It may be dry enough tommorow.
    I did a little work on the side of the house while I was waiting. I decided to builde a wall around where the pump is and I am put in another post to finish the fence. I'm going to have to cut some of the planks to finish the wall though.
    Also there is a pic of the drain installed.
    Jul 2010
    Mickleton, NJ
    229
    very interesting....keep the pictures coming, I can't wait to see the finished product, the retaining wall looks great too.
    Currently Pooless
    Former Pool:Buster Crabbe resin and steel 30'x15' oval 52" ABG pool Pentair sand dollar filter 1.5 Pentair Dynamo pump13,500 gallons
    Here is a little more progress. I got the drain and concrete put in around the pool and I got the dirt backfilled around the wall on the outside. Also a little work on the front of the house.
    22,477
    I like it, but them river rocks are makin my feet hurt!
    May 2011
    lebanon tn
    370
    an Alabama resident without tough feet? I thought shoes were optional in AL, same as GA, except in Jan/Feb? lol...
    24ft x 52in AGP 18000 gal
    sand filter, 200#,1.5 hp single speed pump
    Wood deck (still in progress...)
    Jul 2010
    Central Illinois
    40
    Wow, that's a project
    18' x 54" Round AGP, Hayward pump/Cartridge Filter, 8 Gallon Liquidator, and TF-Test
    Here is a little more progress in the front yard.
    I cut my cable line planting the azaleas
    Still got to get some more pebbles around the front of the flowers
    We excavated the dirt in the back down to where it will match the grade of the pool after concrete is poured. Next we will be forming up the walls to pour the conrete walls first.
    I finished the water fall in the front now.
    Got the deck coming together and the forms for the concrete walls going up.
    The plan is to cover the deck with plywood and concrete board on top of that. PVC trim screwed into the plywood around the pool inside edge. The cement board will have the cracks filled with thinset and then coated with redgaurd sealer. Then the concret will be poured for the floor even with the concreteboard on the deck and then tiled across the deck and the concrete floor.
    Nov 2010
    Calera, Al
    271
    WOW!!! That is quite a project!! looking great, keep the pics coming!!!
    17,000 gal, IG Gunite Diamond Brite plaster Kidneybean,w/7x11 tanning ledge& 3x5 swimout bench,244T 300lb Hayward Pro high rate sand filter(63 GPM) , Hayward 1Hp Super Pump w/3/4 hp booster pump, Polaris 280, Laars Lite 2 175k N/G Heater, Tf-100, Speed stir
    dattia's Avatar
    Jun 2008
    West Chester, PA
    511
    Wow!!!! is right... an ambitious project for sure and it is coming along wonderfully! I love the water feature in the front yard, your entryway is fantastic!
    27' round AG
    Hayward Matrix 1 1/2 HP Pump
    Hayward S210T Sand Filter
  20. Back To Top    #20
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Wow, looks great!!
    Love that liner.
