Results 1 to 7 of 7
Thread: After several days of heavy rain what should you do?
    Aug 2010
    Sarasota, FL
    22
    Living in west coast of Florida and its been raining none stop for 24 hrs and it looks like a few more days of heavy rain. What is the best thing to do after the rain stops?
    20k gal pool/spa, marc, 2 hp pentair whisperflo, Pentair clean & clear filter, Raypack Reheem 266 heater. Taylor K2005 test kit.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,412
    Re: After several days of heavy rain what should you do?
    Test your water and see if you need to bump up any of the chemicals. Have you had to drain the excess water from the pool?
    Love TFP? Become a
    TFP Supporter!
    Aug 2010
    Sarasota, FL
    22
    Yes, I've drained water one time late today.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,648
    The PH will probably be affected the most.
    30,431
    Many, many pool owners are concerned that rain drastically affects your pool water chemistry. It doesn't.
    Common sense tells us that a pool with an average depth of 48 inches receiving 2 inches of rainfall generally dilutes everything in the pool by around 4%.
    So, if your CYA was 50ppm, it's now 48ppm!!
    If your FC was 5ppm, it's now 4.8ppm!!
    pH can take a more significant hit but it's not gonna' drop or rise precipitously regardless.
    The REALLY big exception to this is if you have an inground pool that gets flooded. All bets are off if you have surface water draining into your pool.
    My pool (not to far from yours) flooded over this morning from the heavy rain. That's at least 6" inches of rainfall here in Pinellas County!
    Clearwater, Florida
    12,000 gallon kidney shaped gunite pool
    Pentair Whisperflo 3/4HP Pump
    Pentair CCP420 420sq/ft Cartridge Filter
    Pentair Intellibrite 5G 120V Pool Light
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,052
    Quote Originally Posted by csoukup6
    Circulate the water so it all mixes well, then test it and dose accordingly. Pool Calculator should be one of your bookmarks. Vacuuming helps mix the water well, too. I've found pH remains fairly stable, everything else dilutes. If you need to lower the water level, do that before adding anything; why treat water you're going to dump?
