Thread: Cyanuric acid and bleach
    Split off of this topic. JasonLion
    Do not pour bleach directly on the cyanuric acid. Dilute the bleach and add it away from the cyanuric acid.
    The reaction of an isocyanurate with hypochlorite can result in rapid formation of nitrogen trichloride, which at high enough concentrations will detonate spontaneously with great violence.
    http://www.taylortechnologies.com/Chemi ... ntentID=73
    Support the site
    Re: Can I pour liquid bleach over my CYA ?
    Cyanuric acid, used to raise the CYA level, is not an isocyanurate, and thus not explosive when mixed with bleach. Dichlor and trichlor are both isocyanurates, and can explode when mixed with bleach.
    Mar 2007
    San Rafael, CA USA
    12,082
    I think you meant to say that CYA is not a chlorinated isocyanurate, but your point is still valid. Anyway, there's not much point pouring bleach literally on top of the CYA anyway -- it can just be poured over another return flow or if there is only one return then further away from the return.
    Adding the bleach near the cyanuric acid with a good flow of water should probably not cause any problems. However, I believe that it is a best practice to avoid adding chemicals in close proximity to each other.
    Cyanuric acid can be oxidized by hypochlorite, in concentrated solutions, in the following manner, forming nitrogen trichloride as an intermediate.
    H3Cy + OH- --> H2Cy- + H2O
    Cyanuric acid + hydroxide --> Cyanurate + water
    H2Cy- + 2ClO- --> Cl2Cy- + 2OH-
    Cyanurate + hypochlorite --> dichloroisocyanurate + hydroxide
    Cl2Cy- +7ClO- + 4H2O --> 3NCl3 + 2CO2 + HCO3 - + 7OH-
    Dichloroisocyanurate + hypochlorite + water --> Nitrogen trichloride + carbon dioxide + bicarbonate + hydroxide
    3NCl3 + 9OH- --> 1.5N2 + 4.5ClO- + 4.5Cl- + 4.5H2O
    Nitrogen trichloride + hydroxide --> nitrogen gas + hypochlorite + chloride + water
    Overall:
    H3Cy + 4.5ClO- --> 1.5N2 + 4.5Cl- + 3CO2 + 1.5H2O
    Reference
    Support the site
    Re: Cyanuric acid and bleach
    This side conversation has been moved to The Deep End. Please do not post advanced chemistry in the Just Getting Started area. Thanks JasonLion
    Mar 2007
    San Rafael, CA USA
    12,082
    This post I wrote a while ago talks about the oxidation of CYA by chlorine, but this isn't a particularly fast process. At any rate, it is a good idea to avoid mixing concentrated chemicals in general. Particularly troublesome is Cal-Hypo and Trichlor as shown in this link while this link shows that Cal-Hypo's flammability is a function of its concentration. Also troublesome is acid with chlorine.
