Results 1 to 18 of 18
Thread: Can I add salt to a chlorine pool?
    dorpo75's Avatar
    Jul 2009
    NE Ohio
    256
    I haven't opened my pool yet as it is "spring" but the temps are reading 28
    So here is my question: I have an above ground pool and maintain it with the BBB method, but want to add salt as I hear it makes the water "softer" in feel. How do I go about doing that? Is there a formula, a method, a preferred brand of salt? Is it just wishful thinking on my part to be able to do this?
    Thanks for the answers.
    2005 Dimension One Venture model 370 gal. hot tub. We'll be using the TFP method to keep it clean and ready to use!
    TFP - The Finest Phorum on the Net!
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    Re: Can I add salt to a chlorine pool?
    Yes, lots of people add salt for the reasons you listed. Read the section on Salt in this Pool School article for more information.
    Love TFP? Become a
    TFP Supporter!
    dorpo75's Avatar
    Jul 2009
    NE Ohio
    256
    Thanks a lot. Appreciate the quick response. Now if only the weather would act as quickly.
    Feb 2008
    Denton, TX
    5,061
    It has been recommended on this forum before that for adding salt to improve the feel of the water, you would want to add enough salt to get you to 2000 ppm. Because most pools also have a residual level of salt in the water already, it is a good idea to have a sample tested to determine the salinity of the water to start so that you don't add more salt than you would need to. Because I have used bleach for so long in my pool, the salt level in my pool is around 700 ppm.
    The Pool Calculator can help you determine how much salt to add to get you where you need to be.
    dorpo75's Avatar
    Jul 2009
    NE Ohio
    256
    Woot! (as my kids would say) I will check the salt content of the water if we ever get weather warm enough to open. Thanks for the added info.
    Ft Lauderdale, Florida
    1,455
    If you have your water tested for salt first, that would prevent adding too much. If you're at 0 ppm of salt, adding 25 lbs per 2,000 gallons, you should get to 1500 ppm of salt. Some people have reported feeling the benefits of just adding salt at around 1000 ppm too. It's really all personal preference.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    Jul 2008
    Denver, Colorado
    98
    Can somebody confirm if there are issues doing this in regards to any corrosion on the heater/steps etc. I use the same BBB method and want to make the water softer but pool stores tell me if I was to have a dedicated SWG, I would need an anode or something to ensure to keep corrosion at a minimum.
    Is this all bollocks like I've heard before from them and can just trust this place to add about 1500ppm for that softer feel without dropping $800 on an swg. The money would be much better spent on beers and a big green egg
    thanks in advance.
    oh - where are people getting the salt from for the best price out of interest?
    25k Inground Vinyl - 3ft to 10ft, Tagelus TA-60 Sand, Minimax 400 Heater, Save T3 autocover.
    FIrst, the salt level used without a SWG is around 2,000, noticeably lower than the salt level used with a SWG, which is around 3,000. Second, even at SWG levels of salt there are hardly ever problems. The main risk is to some kinds of natural stone work using softer stone. Anodes are not commonly used even with a SWG. There are some cases where you have a lot of aluminum in direct contact with the water where you might want an anode, but that isn't at all common.
    Jul 2008
    Denver, Colorado
    98
    Thanks Jason....appreciate it.
    Where are most people getting their salt from?
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Pool stores, Home Depot/Lowes etc. with pool departments. You can use water softener salt, with no additives or rust inhibitors, etc.
    Jul 2008
    Denver, Colorado
    98
    Thanks all - Love this site so much
    Here's to a successful opening
    I'm glad I came across this thread as I totally skipped over anything to do with salt and SWG when reading Pool School as I am using chlorine and UV system (figured salt was a no go).
    By adding salt to my pool does it essentially turn my pool into a salt water pool (like using a SWG) with the exception that bleach provides sanitation instead of the SWG converting salt to chlorine?
    The reason I never went with a SWG was 3 out of 4 pool installers in my area talked me out of it stating that they have come across several pools that have had rusted panels from the salt water run off getting under the deck and to the back side of the panel or behind the liner if there is a rip or the liner is coming off the coping.
    I'd like to be able to experience the soft skin and other perks of the salt water that I always hear about.
    76549 Liters -- Cartridge Filter -- In Ground -- Vinyl -- TF-100 Test Kit -- AquaVac Robotic Cleaner -- UV Sanitation -- Winter Safety Cover -- Installed 2010 -- Southwestern Ontario, Canada
    Latest Test Results June 25:
    FC - 6, CC - 0, CYA - 40, CH - 110, TA - 90, pH - 7.5
    Adding salt, without a SWG, gives the water what many people describe as a silky feel, but it doesn't give you any of the other advantages of a SWG. For example you can't use lower FC levels with salt the way you can with a SWG.
    Jul 2012
    Cypress, Texas
    19
    We were also told by 5 different pool builders that they would not put a salt water pool in because of the corrosive effects, so we went with chlorine too. We also have lots of flagstone and an iron gate very close to the pool not to mention lots of metal furniture. I've been using the BBB method and would like to introduce potassium chloride to my chlorine pool for softer water. If I do this, would I still get the corrosive effects like salt is "supposed" to have?
    20K gal, IG Pebble Sheen, IntelliFlo VS 3HP, 60sqft DE Plus 150gpm, Completed 10/2012, 320 Chlorinator (don't use), Del Eclipse 2 Ozone Gen w/MDV, Pentair Legend Platinum Cleaner, Pentair Mastertemp 400K BTU Nat.Gas Heater, 1.5HP WisperFlo Pump for: 4 Weepers, 2 Bubblers, 3 Aerators, 12" Raised Spa w/8' Neg Edge Spillway.
    Potassium chloride and sodium chloride have identical effects in every way, except potassium chloride costs more.
    Jul 2012
    Cypress, Texas
    19
    Thanks that's good to know. I would hate to ruin our new coping and stone work along with all our other furniture.
    Apr 2013
    NW Ohio
    83
    so whats the reports of users and salt around pools? and negative effects of the salt? The corrosivness of salt still concerns me but I want to add it at a lower concentration 1000-2000ppm for that feel!
    I don't have a lot going around pool that is metal, but galvanized panels and aluminum step rail cups. Should i see issues long term at all? Say over next 5-10 yrs??
    18x37 Vinyl Grecian (24k gals) 8' Inter fab(la mesa) Diving board w/ waterfall & Led, Pentair Laminars & Intellibrite 5g
    Star Rite System 3 Cartridge Filter, IntelliPro 3HP Variable Spd Pump, Max E Therm 400k BTU,
    Pentair Easy Touch 8 & actuators,...Now looking to BBB
    Jul 2012
    Cypress, Texas
    19
    We live in Houston and just built our pool 6 months ago. We met with 10 builders and only two of them would even put in a saltwater pool, so we opted for chlorine. They all said that within 5-7 years you completely have to replace all your coping and natural stone. Not sure about the low levels of salt; however, if you are using the bbb method you are adding salt to your pool and the borates make the water feel great too.
