Thread: How much salt is too much
    Nod's Avatar
    Jun 2008
    Nashville, NC
    69
    I just purchased a compupool SWG and put in my bags of salt. However according to my test strip I have 4400ppm, and the SWG calls for 3500? Do I need to remove water, or will it still work, and I just let splashing/backwash clear it out over time?
    ~Nod
    Nod
    16x32 IG, polymer panel Vinyl Pool w/approx 21k gallons of H20
    1 HP Hayward Pump & 300lb Sand Filter ~ Polaris 280 Pool cleaner
    ~~Nashville, NC~~
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: How much salt is too much
    Unless the system give you a high salt error and the unit is making chlorine, you should be OK.
    Jul 2007
    Brisbane, Australia
    874
    with the exception of when your cell has died or is dirty and your system shows 'low salt' when in fact you've got plenty
