Results 1 to 10 of 10
Thread: Can we "gently" power wash the liner before we refilling??
    Jun 2010
    Levelland Texas
    125
    We will be draining our pool and refilling it this year upon opening....I have other threads discussing SWG which we are converting to....but my question is:
    Could we "gently" power wash the vinyl liner upon cleaning as we have a lot of calcium/mineral scale buildup a long the walls??? We would do this "before" draining the swamp water out as to not stretch or "move" the liner in anyway....
    Any advice on this would be most helpful.....Thank You!!
    New 22' round, 52" deep Coleman (Bestway) AG/10,500 gal/16" Intex sand filter with over the side skimmer/Levelland TX (Lubbock area)
    Jan 2010
    Central Valley, CA
    233
    Re: Can we "gently" power wash the liner before we refilling
    I'm not qualified to fully answer but while you wait I'll warn you that except for intex type pools, liners shrink when drained and can't be reused. You could probably drain partially and refill but I'd research it carefully starting with searching this site.
    Garden Leisure Voyager 12x24 AGP, 7500 Gallons, Hayward Power Flo Matrix 1 HP pump, dual speed, Hayward XStream Cartridge Filter, 120 GPM,
    Jun 2010
    Levelland Texas
    125
    We weren't planning on draining it completely but with the water level dropping so low over the winter it has a lot of deposits on the walls.....that is what we were wanting to clean with water spray?? ...Or is there any type of cleaner we could use??
    Please let me know what anyone thinks on this idea....Thanks
    dmanb2b's Avatar
    Apr 2009
    NY
    3,728
    Any pics? It may just need a good brushing or perhaps light application of magic eraser and some elbow grease. It's fairly unusual to have calcium build-up on a liner pool. If you have some pics, it may help us vizualize better, but I would not drain the pool any further.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,376
    Does the residue wipe away easily or do you have to scrub to get it off? I would try brushing it with a pool brush or scrubbing it with a Mr.Clean magic eraser. Power washers can damage an older or brittle liner and could cause tears where opening were cut for skimmers and returns.
    Love TFP? Become a
    TFP Supporter!
    Jun 2010
    Levelland Texas
    125
    Thanks for the responses.....the scale should brush away with a lot of effort....I will post some pics if I can ever find my camera....
    Scale build-up is very common where I live because the water is beyond HARD.....
    So, that being said, I'm hoping switching to the SWG will help with this in the long run...first have to deal with the left over swamp that the winter left us...
    Thanks again!!!
    dmanb2b's Avatar
    Apr 2009
    NY
    3,728
    Switching to a SWG actually promotes PH rise, which promotes calcium scaling. Keeping ph at 7.6 and below will help avoid scaling issues.
    Jun 2010
    Levelland Texas
    125
    Quote Originally Posted by dmanb2b
    Well.....I have always had trouble with high pH due to our hard water....but I should be able to keep it in check with the dry acid right?? Even with using the SWG??
    dmanb2b's Avatar
    Apr 2009
    NY
    3,728
    "Hard" water does not cause PH rise. Your water likely has a high TA, but I'm guessing that, which is causing PH to rise, not hardness. We prefer using muratic acid vs dry acid as it contains sulfur.
    Jun 2010
    Levelland Texas
    125
    Okay...thanks!! Actually it is muratic acid that I have used....wrote the wrong type....anyway should be tackling our pool soon....so may have many more questions at that time..
