Thread: Solar Cover Reel installation Above Ground Pool
    Hi, I have a 24ft round Above ground pool. I picked up a solar cover reel, the problem I am having is it is designed to mount to the top rails of the pool. Mine doesn't have any. it has decking around half of the pool, and fencing around the rest. I was told you shouldn't install it in the middle of the pool, only off to one side. So far the biggest problem i have had is it doesn't mind up well or come off of the roll well. I am thinking of doing a couple of things
    1.Installing pull ropes on each end to assist in unrolling the cover (i see commercial products to do this, but anyone have any better methods? (or see step 2, i could use those straps)
    2.Removing the outer straps (there are 8 of them, 6 should work fine) and flipping in the sides before rolling
    i do have it secured to the deck and the end, but I was trying to avoid putting the mounts where people walk, as they might get hurt (they're plastic, and aren't sharp, but most likely some body will brake them.)
    Bel Air 24' Above Ground Round Pool
    Hayward- GM152 Sand Filter
    Hayward- SP711-13 Multi-Port Valve
    Hayward- SP1511 Pump 3/4HP
    Hayward- SP1092 Skimmer
    Hayward- SP1411 Return
    Polaris 65 Cleaner
    NWMNMom's Avatar
    Waaay NW MN
    Well the rope idea is good. Ours is installed on posts off the end as our deck is at the other end. We have something similar to the rope/straps.
    Any pictures you can post to help figure out what may assist with your problem?
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    Apr 2016
    Canton/ CT
    Re: Solar Cover Reel installation Above Ground Pool
    Can you provide pictures. Trying to see what is the best way to go.
