Results 1 to 10 of 10
Thread: Polaris booster pump leaking
    Mar 2010
    Spring, TX
    1,082
    Ok got my other problem resolved as I am sure this is much easier one to solve.
    In the picture you will see a black ring where the pvc connects to the pump. It is leaking here. I assume I just need to tightned it up some. Is there anything else I need to do to this?
    Thanks.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Re: Polaris booster pump leaking
    Try that first, if it doesn't work you may need to put some teflon pipe dope on the threads.
    Love TFP? Become a
    TFP Supporter!
    Mar 2010
    Spring, TX
    1,082
    Quote Originally Posted by zea3
    I guess I shoudl make the black part go closer towards the booster or further away. My guess is closer to the booster?
    Thanks.
    Yes, closer, except I'm not sure it will turn. It may well be glued to that pipe and not turn without breaking something. Don't use too much force.
    Mar 2010
    Spring, TX
    1,082
    I tried turning it early and it seem to turn pretty easy. But didnt really try too much.
    Mar 2010
    Spring, TX
    1,082
    Well it seemed as you said the glue came loose but no breaking at all. So what is the best stuff to use to reconnect the pipes.
    The part where the black thing is a connector from the pump to the white things. The white thing connects to the pipe that goes back to the pool. So I need to use some pipe glue to reconnect the connector and pipes. The part I am talking about is circled in black.
    Jul 2009
    Houston, Texas
    9,379
    If the connection is threaded use some teflon pipe dope. If the connection is smooth use pvc primer and cement. Those can all be found at the hardware store.
    Love TFP? Become a
    TFP Supporter!
    Mar 2010
    Spring, TX
    1,082
    I guess this will work along with pvc primer. The following is the cement
    http://www.homedepot.com/h_d1/N-5yc1v/R ... ogId=10053
    The following is the primer
    The only thing I am worried about is when you apply this stuff you are supposed to put the primer and then the cement and insert and turn. Will it be ok since it seems to be a pretty tight fit to put the primer on then the cement and just push them together?
    Thanks.
    If you have enough pipe flexibility to be able to pull the joint apart and clean it, then everything will be fine when you glue it back together even without a twist. The less leeway for movement there is, the more complex the entire operation becomes.
    Mar 2010
    Spring, TX
    1,082
    Yea there is enough leeway to pull it apart. I already experienced that when I turned on the polaris while trying to get it tight it just popped off. It appeared to be very clean and I am suprised it has not come off sooner. So I have turned off the small water hose that sends water to the booster pump. So as of now it is not leaking. So hopefully this weekend I can get it all fixed up.
    Thanks everyone for the help.
