Thread: I have a hole with nothing to go in it
    Jul 2008
    Cape Coral, FL
    24
    Im hoping that draws some attention. We have a bahama step with a plastic grommet type hole in it. It looks like it may be there for a table or an umbrella. The problem is we cant find anything to fit. I measured the diameter last year, but forgot the measurement. Somewhere around 2 inch though.
    The wife really wants a table for there so who makes things like this?
    90ft perimeter plaster pool, 14000 gallons, plastic slide, rock waterfall, Bahama step, Polaris Auto Clear Plus SWG, a pump and filter( will update later)
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,409
    Re: I have a hole with nothing to go in it
    This sounds rather personal but can you post a picture of your hole? Do you know who built the pool? If so they may be able to identify a vendor that can fill your needs. Have you checked with any of the local pool stores?
    Love TFP? Become a
    TFP Supporter!
    XsAllOverIt's Avatar
    Dec 2010
    Mount Airy, Maryland
    560
    If it's a 2 inch hole, you can certainly fit an umbrella in the hole by creating a smaller sleeve with some pvc pipe.
    18 x 36 Inground Gunnite, White Plaster 21K gallon
    18" raised spa, 8' Diameter (620 gallon)
    Triton II Sand filter, Intellichlor IC40 SWG
    Pentair Pump, Max-E-Therm 400 BTU
    Lamotte ColorQ PRO 7-Plus test kit
    TFT-100 test kit
    Apr 2010
    Buckeye, AZ 85326
    619
    Here is what we did as far as the sleeves.
    Before sleeve
    With sleeve
    Sleeve and umbrella pole
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    Feb 2008
    Denton, TX
    5,061
    That's pretty nifty there Shane. I like it!
