Results 1 to 8 of 8
Thread: Pentair Superflo seal replacement How-to remove impeller?
    I am having trouble getting the impeller off - I understand that in unscrews counterclockwise ... but I have tried the vise grips and really have tried to unscrew it but it won't budge ... any help with suggestions ... thanks
    22,553
    Re: Pentair Whisperflow seal replacement How-to (w/ photos)
    Lone Eagles, tell me which pump you have and I'll move this to it own topic so you'll get better response.
    it is a Pentair SOFL 2HPF ... on the placard it has Y56Y - Type CX and Form KJM
    Part Number 075236S ... Serial Number 0395163090002V
    This pump has been a pain in the rear since Cody Pools put it in ... The pump/filter is above the pool by probablysix feet ... but I thought they would know how to "plumb" it so it would work and not lose prime after a couple of months ... since July of 2009, I think they have put in 6 to 8 seals ... I was never home to watch - but the last time the Tech left me a spare seal ... I thought it would be a walk in the park ... As usual ... the home DIY is a little more than it should be ...
    Where in AL ... landed at Bay Minette just the other day ... son was at Enterprise for a couple of years at Mother Rucker ...
    Thanks for the help ... Blue Skies .... LE
    22,553
    Re: Pentair Superflo seal replacement How-to remove impeller
    I'm about an hour from Bay Minette and about 3 from Rucker. BIL retired from Rucker. He was an IP.
    Hopefully some of the pump guys (or girls) will stop by and give you a little help.
    Jun 2008
    San Antonio, TX
    129
    Like the Pentair Whisperflo, the Superflo may have an impeller locking screw. Just look into the impeller inlet...in the middle should be the small hex-head lock screw. Hope this helps.
    E
    Aug 2007
    near the swamp
    806
    There's a left handed screw on the impeller. Now look on the back of motor and there is a metal/plastic cap, pop or twist it off, use a 9/16 wrench to hold shaft or use vise grips. Now spin the impeller off counterclockwise.
    Do the opposite to reinstall.
    Rock'n Roll ... Thanks ... once I found out about the cap in the back and able to get a hold of the shaft (the Cody Tech called with help as well) .... Thanks for the help and thanks for the orginal post on "How To Change the Seal" Now to change the seal in the "polaris" pump .... I hear it is the same seal ... just more bolts .... Blue Skies ... LE
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    If you have anymore problems with your Pentaire equipment, they have a forum on their website that is monitored by one of their technicians M-F. They are a great resource for warranty issues and troubleshooting their equipment.
    Love TFP? Become a
    TFP Supporter!
