Results 1 to 7 of 7
Thread: water levels after winter
    Hi
    My first winter with the 30' round above ground pool and I think the water level might be lower than it should be.
    Its still hard to tell because it has some ice on it but I would guess if it had 4 feet when I closed it up it now has under 3 feet. maybe 2 1/2 ish give or take.
    Is it normal to loose water level over he winter or might I somehow have a leak?
    Also to add some detail a small portion of the cover had been pulled into the pool creating a gap of about 3 feel long and 1/2 foot wide I could not fix it because of how harsh the winter was but 97% of the pool cover was intact fine
    thoughts
    25,500K gallons; cartridge; IG; plaster; I'll have to look up the pump size and flow rate
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: water levels after winter
    I lost about 18-24" through a bad skimmer plug It's normal, just raise it up as soon as you can
    how do I know if its a leak in the liner or normal
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    If you fill it up and it goes back down without any significant rain or snow on top of the cover, then it's a leak. That said, your likely fine...I had 2ft of water on top of my cover the other day after the snow and ice melted, that pushes any water in the pool up and out threw any opening.
    Casey's Avatar
    SW PA
    10,457
    Quote Originally Posted by dmanb2b
    Exactly what I was about to post. You should be fine.
    This is our 1st winter with an above ground pool too. We seemed to have lost about a foot of water. The cover was removed today, everyting looks fine, no obvious leaks etc... Is this normal to loose that much water? We plugged the skimmer opening, removed hoses & drained water to skimmer.
    We live in NH, 27' x 52" --- we did have 'tons' of snow this season, it would make sense if the water became displaced.
    So, is this relatively normal? Thanks much!!!!!
    Nini from New England
    27' AG 52", 18,500 gal
    Proline 22" Sand Filter, Proline 2hp 2 speed pump, Proline chlorinator
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    It's normal if you get enough rain/snow to displace the water. Happens to me all the time.
