Thread: Non-Polymer Filter Aid
    I am getting ready to work on removing iron stains from my fiberglass pool. I will be using Stain Free by Natural Chemistry. In the instructions, it mentions using a "non-polymer filter aid (paper pulp products work great for this process)" if you have a sand filter. What is a non-polymer filter aid and where do I get one?
    Thanks for your help!!
    Dory
    East TN
    13,000 gal San Juan Fiberglass Pool;SWG; GoldLine Pro Logic Controls
    Hayward Sand Filter; Hayward Max-Flo XL Pump;Polaris 380; Hayward ColorLogic LED
    Raypak Gas Heater
    South Central NJ
    3,192
    Re: Non-Polymer Filter Aid
    Its DE substitute.
    Scott
    Owner of - PoolGuyNJ LLC
    Mar 2007
    San Rafael, CA USA
    12,082
    An example is Fiber Clear where you can get a small bag through Amazon. Be careful not to use too much as it filters to very small particles so can back up pressure significantly if the pool isn't clean (and it won't be when using these metal binding products since it sounds like they are intended to capture the sequestered metal in the filter).
    How do I add the filter aid for example Fiber Clear to the sand filter? Do I have to open the sand filter or can I put it in the skimmer?
    Thanks!!
    East TN
    Raypak Gas Heater
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,409
    Remove the skimmer basket and turn on the pump. Add about a cup of fiber clear to the skimmer. Watch the pump basket, when you add the fiber clear the water will turn milky. Once it has all been sucked into the filter the water in the pump basket will be clear again. Just add a little at a time until you have added the recommended amount. Then you can put the skimmer basket back in place.
    Love TFP? Become a
    TFP Supporter!
    Thank you so much for the help!! I am going to order some and give it a try.
    East TN
    Raypak Gas Heater
