Results 1 to 12 of 12
Thread: Wet around pump
    Mar 2010
    Spring, TX
    1,082
    Wet around pump
    This is the first time I have noticed this. I have noticed the past few days that around the base of my pump there seems to be some wetness. Not sure why this has happened. Anyone have any suggestions on why this is happening?
    Thanks.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    South Central NJ
    3,192
    Re: Wet around pump
    It's likely the seal set needs to be replaced. If you look under the pump motor and see it dribbling, they need to be replaced. What pump?
    Scott
    Owner of - PoolGuyNJ LLC
    Mar 2010
    Spring, TX
    1,082
    Re: Wet around pump
    Here are some pics.
    Mar 2010
    Spring, TX
    1,082
    Re: Wet around pump
    A few more
    South Central NJ
    3,192
    Re: Wet around pump
    Super Pro brand seal set SPG-1000. Same seal set as a Polaris booster. ett it done before you toast the motor.
    Scott
    Mar 2010
    Spring, TX
    1,082
    Re: Wet around pump
    Quote Originally Posted by PoolGuyNJ
    Scott
    I cant seem to find that seal set? Also any instructions on how to change this out? What do you mean before I toast the motor? I know you mean have it go out, but why would it toast the motor? Is that because it is not getting water?
    Thanks.
    Mar 2010
    Spring, TX
    1,082
    Re: Wet around pump
    Scott
    Is this it?
    http://www.yourpoolhq.com/pool-pump-sha ... g1000.html
    Jan 2011
    153
    Re: Wet around pump
    It's very easy to replace the seal if you go up to Professional Pools just tell the you need a ps1000 like poolguynj said..The link you post is the right seal...
    Mar 2010
    Spring, TX
    1,082
    Re: Wet around pump
    Quote Originally Posted by Keven
    Thanks for the help. How much of the pump has to be taken apart to replace this seal? I have never taken apart the pump so this is all new to me.
    Thanks.
    Jan 2011
    153
    Re: Wet around pump
    Quote Originally Posted by mynewpool
    Thanks.
    It's 4 bolts that hold the seal to the pump housing.. Threw the holes you can see the shaft of the motor you well need to use something to hold the shaft from moving.. What I do is take a long screw driver and pop the seal out from the back side..Once you get the seal out put a little bit of silicon around the metal part of the seal, I use a 1.5 inch male adapter and tap the seal into the seal plate.. Then just put it back together like you took it apart..
    If you have very little mechnical skills you can replace the seal..
    Mar 2010
    Spring, TX
    1,082
    Re: Wet around pump
    Thanks.
    Is it those 4 bolts closest to the motor pump or the bolts that hold it to the basket in front of the pump? Since you do pool work would you be willing to come by and help me out?
    Thanks
    Mar 2010
    Spring, TX
    1,082
    Re: Wet around pump
    Seal was the culprit. Got it replaced today and no more leaking.
    Thanks TFP
