Results 1 to 14 of 14
Thread: 3 Inch Tablets
    3 Inch Tablets
    I'm using BBB now but would like to use the tabs for when we are away. Does anyone make just chlorine tabs that aren't di or tri chlore? I don't want to raise my CYA anymore but the tabs can be verrry handy!
    crookm11's Avatar
    Jun 2010
    Copperas Cove, Texas
    422
    Re: 3 Inch Tablets
    Hello,
    I have only one season using the BBB method and have a thought. How long are you going to be away? If you have your CYA at the correct level already, couldn't you just raise your FC in the pool right before you leave and cover the pool to minimize the FC loss while your gone?
    Mark Crook
    13,500 Gallon 24' x 52" Intex Ultra Frame
    Intex Sand Filter and Pump, Intex SWG (All hard PVC plumbed)
    TFTestKit-100---Pool School---The Pool Calculator
    Location: Copperas Cove, Texas --- My Pool Build---Useful Links for Intex Pool Owners
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: 3 Inch Tablets
    Quote Originally Posted by crookm11
    Hello,
    That's what I do...a 10ppm increase (or boost) will last at least 5 days in a well balanced pool with a solar cover over it.
    JoshU's Avatar
    New Orleans, LA
    542
    Re: 3 Inch Tablets
    Yep, Cal-Hypo tabs are out there. They aren't used in residential applications all that much. Sometimes you can find some HTH tabs @ Walmart. Just make sure you don't mix them up tri-chlor tabs or put them in the same feeder where tri-chlor tabs once sat.
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: 3 Inch Tablets
    Anyone know if you could use cal-hypo tabs in a floater?
    Re: 3 Inch Tablets
    Cal-hypo tablets tend to dissolve way too quickly. I've seen various approaches to trying to control that, but nothing simpler than a specialized cal-hypo tablet feeder for use at the equipment pad seems to work reliably. The various cal-hypo floaters, and cal-hypo containers designed to be put in a skimmer all seem to be too inconsistent for practical use.
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    Re: 3 Inch Tablets
    Quote Originally Posted by like2lean
    I use trichlor tabs in an auto-feeder when we're away. Our vacations are usually for 6 weeks in Aug/Sept, a very long time to leave a pool unattended. I plan for it from the beginning of the season by keeping the CYA at or slightly below 50 so that I have room for an increase when using the trichlor tabs. We live in a climate where CYA disappears over winter so a higher level at the end of the season doesn't concern me.
    During the swim season I use liquid chlorine and add granular CYA only at the beginning to get to about 50.
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    Re: 3 Inch Tablets
    Quote Originally Posted by AnnaK
    Wow I didn't know CYA would drop over the winter, I've heard a drain was in order for highter level correction...
    So are the Cal-hypo tabs straight chlorine with no stabilizer? Do they raise calcuim levels?
    Re: 3 Inch Tablets
    Cal-hypo raises CH levels.
    CYA only sometimes drops over the winter, and usually only when you get algae over the winter. It would be very very nice if there was a way to get the CYA drop to happen on demand, but there isn't (yet).
    AnnaK's Avatar
    Jul 2007
    1,134
    Re: 3 Inch Tablets
    Not to put too fine a point on it but we don't get algae over winter. Our pool freezes into a solid block. We end the season with chlorine at shock level and CYA around 60 and we open in mid-April to clean clear water at around 45 F, no FC, no CYA. And NO algae.
    AnnaK
    Re: 3 Inch Tablets
    and usually only
    The process by which CYA goes away is difficult to predict, it can happen without algae, it is much more likely to happen with algae. It can happen every year for some pool, and never happen to apparently identical pool next door. You are lucky that you can rely on it, most people can't.
    ChiknNutz's Avatar
    Jul 2010
    Arlington, WA
    145
    Re: 3 Inch Tablets
    Hope I'm not hijacking this thread, but my question seems to fall right in line with the OP. So, are there non-stabilized (as in no CYA) Trichlor 3" tabs? I am now considering something like the Liquidator so I don't add too much CYA, but seems to be this whole process would be SO much simpler if I could just use non-CYA tabs in my feeder! We get so much precipitation over winter that my CYA has dropped from 60-30 due to numerous partial drains, but that's now just about right for the CYA level.
    Chris A.
    20x40 36k gal IG vinyl pool w/diving board & slide | 1.25HP Pentair Challenger motor & pump | 30" Triton TR100 sand filter | Pentair SM-20-3 multiport | Stenner 45MHP2 Peristaltic Pump & 13 gallon carboy (BBB) | Hayward CL200 Tablet Chlorinator (used on pool startup) | TF-100 | 2003 Sundance 850 Altamar hot tub
    30,419
    Re: 3 Inch Tablets
    There's really no alternative tablets....only tri-chlor (that add CYA pretty quickly) The Cal-hypo tabs are, as Jason said above, really unreliable and simply not very practical for pools. (FWIW, they are frequently used in septic systems where a sanitizer is required)
    Oct 2010
    Houston, TX
    152
    Re: 3 Inch Tablets
    Quote Originally Posted by ChiknNutz
    That would be the Holy Grail if there were tabs like those...
    15k gunite pool. Intelliflo VF. Autopilot SWG.
    2k separate spa with waterfall (ie: pain in the rear maintaining a separate body of water). 2HP Hayward Tristar pump.
