Results 1 to 7 of 7
Thread: Tail on Pool Cleaner
    ajones02's Avatar
    Feb 2010
    Keller, Texas
    118
    All,
    I have a Legend Kreepy Krauly and as most do it came with about a 3 foot tail or sweep. My question is can the tail be reduced in length and if so, does it have a negative impact on it performance?
    The reason for the question is that when it crawls up the the wall and gets close to the water line, the tail comes out and shoot water out of the pool. I believe this is my main source of water loss over the past year and want to try and limit this. Also, the water more often than not ends up on the windows and storm door on the back of the house and needs to be cleaned multiple times a week. One of the pool builders we had bid on our pool project mentioned that since we wanted salt water that the pool cleaner would need a shorter tail to reduce the amount of water coming from the pool.
    So, any thoughts would be greatly appreciated as always!
    17,800 gallons, Pentair Clean and Clear 420 Cartridge Filter, Inground, Blue Granite Pebblesheen Interior, Pentair Intelliflo VS-3050 Pool and Spa pump, Pentair Whisperflo 2HP Water Feature pump, Pentair .75 HP Booster Pump for Pentair Legend pool cleaner, Pentair EasyTouch 8-function remote, Pentair IntelliChlor SWG.
    Feb 2008
    Dallas, TX
    60
    Re: Tail on Pool Cleaner
    I have the same problem with a Polaris 280. I believe there is a weight that Polaris makes to attach to the tail. In water the weight doesn't matter much, but it does keep the end from going above the water line. If Kreepy Krauly doesn't make a weight perhaps the Polaris weight would work for you.
    Also, in cool/cold water the hoses are stiffer and the problem may be worse. I found a good section in this link.
    31000 Gal IG L-shape w/ spa, Riversand finish (PebbleSheen clone)
    Jandy 60 sq ft DE, 2.5 HP (uprated) Stealth pump, Polaris 280 w/ booster, Jandy PDA PS4 controller
    JoshU's Avatar
    New Orleans, LA
    543
    The amount of water coming out of the tail should be adjustable. I'm not 100% sure of how to do this on the Kreepy unit. On a Polaris you should see a small thumb screw near the tail and the tighter you make it the less water will come out of it -- reducing the speed/velocity at which it whips out of the pool.
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
    ajones02's Avatar
    Feb 2010
    Keller, Texas
    118
    thanks for the replies!!!!
    i will check the owners manul tonight and see if there is an adjustment on the back.
    Aug 2007
    near the swamp
    806
    Quote Originally Posted by JoshU
    ^THIS! But it usually increases the speed of the cleaner. I know of some poeple that don't like it moving around that fast, it skips some spots of their pool going at warp speed.
    ajones02's Avatar
    Feb 2010
    Keller, Texas
    118
    hhhhhmmmmmmm, and that brings me back to my original question. can the tail length be reduced without impacting performance?
    JoshU's Avatar
    New Orleans, LA
    543
    Quote Originally Posted by DBfan187
    Once the tail is adjusted you need to adjust the wall fitting where the Polaris connects to the return jet of the pool to bypass more water directly to the pool instead of into the hose.
