Results 1 to 7 of 7
Thread: Transfer pump
    Jan 2011
    Australia
    116
    Transfer pump
    Trying to pump out groundwater after heavy rain.
    Have moved pump out of excavation above pool and attached quite a long suction side hose but now having probs.
    Is there a limit as to the length of suction side hose and height of pump?. when hose was short and pump down in excavation, pump was working but I need to have the pump out of the pool area. Is this just a matter of insufficient priming water in the suction hose or too long a hose/too high a pump?
    thanks
    11k gallon IG Ferrocement , Onga (Pentair) SF750 1hp pump, Onga Pantera MK11 PCF200sqft Cartridge Filter, Watermaid WM40-QT300 SWG, Spa Electrics GK7 LED
    Dec 2009
    Central Massachusetts
    2,690
    Re: Transfer pump
    You have to look at the pump size. The insert that came with it should tell you what it will pull in terms of height.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    30,408
    Re: Transfer pump
    Almost surely that is the issue.
    Jan 2011
    Australia
    116
    Re: Transfer pump
    Quote Originally Posted by bk406
    It says 7 metres suction height max. I have an 11 metre hose on there but the actual height difference is only 1.5 metres.
    What would be the max length of pipe (1.5") with a height of 1.5m?
    Re: Transfer pump
    It may be a question of getting the pump to prime correctly. If the suction hose starts out full of air the pump will have a very hard time getting going. If you can fill the suction hose with water, keep the suction end blocked off, lower the section end into the water at the bottom and then turn the pump on and release the seal on the pipe at about the same moment it might well get going from there.
    Jan 2011
    Australia
    116
    Re: Transfer pump
    I cut the pipe to the shortest length possible, primed with a hose and got the thing going.
    Only problem now is when the water level drops, the hose gets air into it and pumps intermittently. Will fit a valve which will stop air getting in; the only trouble with that is it keeps getting blocked with twigs etc. Tried putting a sock etc over the end, but they kept getting blocked.
    Fortunately I found there is a non return valve on the suction side of the pump so the prime water cant get out.
    Jan 2011
    Australia
    116
    Re: Transfer pump
    Appears its not air but the pump running faster than the water can get to it now that the level is quite low.
    Fitted a valve on the out hose to restrict flow and put the pump on low revs: seems to have done the trick. Sweet spot between water flowing to
    sump and pumping speed.
