Results 1 to 15 of 15
Thread: PB Install or Self-Install Easytouch with IC40 Cell
    Feb 2011
    Cincinnati, Ohio
    106
    Our pool will be started in about a month. As of right now, we were just going with a standard manualy dosed chlorine pool. I have no decided that I think we should go with the Easytouch and IC40 cell because we will have a 2 spd pump, Intellibrite lights and I want to put in solar this summer. The PB will charge me $1500 to install this including the salt and initial setup to get everything right. I will also get the 3 year extended warranty if I have him do it.
    I can buy it online and have it shipped to my house for around $1100 or so. I would then need to buy salt and install it and only have the 1 year warranty.
    My question to you is do you think I should just have the PB install it for a little extra money and get the extended warranty?
    Just wanted some opinions on this.
    18 x 36 IG Vinyl Liner 28K Gallons
    Pentair Intelliflo VS+SVRS, Pentair CC + 420 Cartridge Filter, Easytouch CP with IC40 SWG
    2" Suction and Return Lines - 2 skimmers, 6 returns
    Dolphin Diagnostic Advantage Robot
    Re: PB Install or Self-Install Easytouch with IC40 Cell
    For me, this is easy, let the PB do it. $400 is very reasonable compared to a discount Internet price, plus you get the warranty and don't need to worry about doing the work yourself. $400 compared to a full pool build is nothing.
    Oct 2010
    Georgia
    317
    Salt is going to cost over $100.
    For the additional 2 years warranty and to have someone install and configure the Easytouch for the 2 speed pump and the lights, an additional $300 is worth it.
    poolschoolgrad
    20x40 free-form IG vinyl, 1hp Hayward superpump, Hayward pro grid DE filter, Raypak heatpump, Goldline Aquarite SWCG, Polaris 280 with booster, and tested using a Taylor K2006.
    Jan 2011
    153
    Let the PB install it that's a no brainer...
    Mar 2011
    441
    Quote Originally Posted by Keven
    I think something isnt right here. Easytouch + IC40 + installation for $1,500? Wiring, wire, programming, adding salt, and follow up if needed??
    Sheesh I'd get him signed up right now.
    I could make money off him/her and never have to leave my office.
    20X40 30,000 gallon gunite pool
    Dec 2009
    Central Massachusetts
    2,690
    Does the $1500 include the wire that needs to be run out to the box? Or is it just hanging the box, wiring it to existing power, and the rest of the equipment install?
    Those Easytouch boxes can be wired with between 60 and 100 amps. Depending on how far he has to pull power from the main, that cost will vary.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Feb 2011
    Cincinnati, Ohio
    106
    Sorry guys. I should have explained it better. I have to run about 30 ft of wire and mount it to my house. I have to get power to it because he is not allowed to because they are not electricians. He will do the rest.
    I don't need a separate controoler or remote do i?
    Dec 2009
    2,690
    Quote Originally Posted by briansturgeon
    No. Pentair has a remote that you can buy, but it's not needed. How much power are you goin to run ut to the ET box? More is better. 30 feet isnt that far. Can you run it through a basement or will you have to dig and bury it? Are you going to hire an electrician to do it?
    Jan 2011
    153
    I dont understand way doesn't hire an electrician to run his main power line and connect power to the breaker box... I understand why he doesn't, that might have the same law as we do where I am at..
    Dec 2009
    2,690
    Some jurisdictions allow you to do your own electrical work as a home owner, but not for hire.
    Jan 2011
    153
    Quote Originally Posted by bk406
    I understand that, but why not hire an electrician to run the lines not leave it up to the homeowner..
    Feb 2011
    Cincinnati, Ohio
    106
    My brother does a lot of electrical work while running his hvac business. He is not licensed electrician but the homeowner is allowed to do electrical work for themselves where I live. A contractor just can't do it if they aren't an electrician. Therefore, I am going to have him help me run the electric to it. I will run the largest I can to the ET.
    I can come out of the basement within about 20 ft or so of the box and the rest I will just did a trench for and run in schedule 80 conduit.
    I'm sure the PB would sub it out if I wanted but them I'd be paying for something that I can do. THe only other thing I need to do then is run power from the ET out to the Intellibrite lights where they are stubbed out. What size wire should I use to run out to the lights?
    Dec 2009
    2,690
    I'd run at least 80 amps out to the ET box. 100 is better. 4 wires, stranded, black red, green, white. #4 for 80 amps, #2 for 100 amps.
    As far as the intellibrites, #12 stranded, black, white, green. How far are the lights from the ET box?
    Is the ET box attached to the house or detached? If detached, how far away?
    Lots goes into wiring a pool. It's not hard, just a lot of detail to know and be aware of.
    Bonding the pool properly is a big job too.
    Feb 2011
    Cincinnati, Ohio
    106
    ET box will be attached to house unless it is better otherwise. On Pentair's website it says "Include 150 amp breaker base with space for 10 1-in breakers" so I'm assuming I can run 150? If so, I can still use #2 wire right? The run from my home 200 amp service will be no more than about 30 feet or so.
    One IB light is about 30 ft and one will be about 60 ft from ET.
    PB is bonding the pool even though I'm having a different contractor do the concrete deck.
    Thanks
    Dec 2009
    2,690
    Ok, Pentair upped the amps in the box then. For 150 amps, you need bigger wire. Honestly, 100 amps is plenty (24,000 watts). That will run a pump, lights, outlets, SWCG, and even a big heat pump if you ever installed one.
