Thread: Wnterized above ground pool. Raise the water back up or no?
    54" tall above ground pool in NY.
    Winterized properly with a solid cover. (water full, skimmer and return plugged)
    After all the tons of snow and rain a lot of pool water got displaced out of the pool.
    Now that I have drained the water from the top of the cover the actual level of the pool water is about 30". Should I raise it back up, or just leave it till spring?
    Likwidskateboards.com
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,602
    Re: Wnterized above ground pool. Raise the water back up or
    It's spring in Texas!..........Whatcha' waitin' on! Water temp 72 here.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Raise it up neighbor Just like mine the skimmer door probably leaked. With some more rain, I did not like all the pressure being put on the cover with the water so low.
    Quote Originally Posted by dmanb2b
    Ok, I will. I have no way to circulate the water, do I need to add chlorine and balance the PH after I raise it back up?
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Nope...you can tackle that when you open the pool up. Just stick a garden hose under the cover and add 12" or so of water. Wow...just checked your website...literally right accros the river
    Oh sweet. Thanks.
    Poughkeepsie?
